It is currently Tue Oct 07, 2025 12:04 am
PostPosted: Sun Aug 16, 2009 10:51 pm
Some more pics of the Toyota Celica ST205 Group A which appeared at this years Goodwood Festival of Speed. Makes an interesting comparison with Neal Bates Australian spec ST205 Group A. Most notable difference is the tubular rear subframe. According to the Irish crew this is an original feature of the car.
PostPosted: Fri Jan 21, 2011 11:29 pm
do you possible know what the blue item is?
looks like a part of the WI to me?
or do you know what kind of WI-pump they use?
PostPosted: Fri Jan 21, 2011 11:48 pm
Coke tin?
PostPosted: Sat Jan 22, 2011 12:19 am
Car Model: ST165
ST165 turbo 4WD
PostPosted: Sat Jan 22, 2011 1:15 am
In that picture above that Gary posted.
The brown bits look like the sockets you would plug an ignition lead onto.
The green bit looks like some sort of solonoid. The blue thing only appears to have vacuum hoses running into it so perhaps some sort of charcoal cannister type thing?
PostPosted: Sat Jan 22, 2011 12:16 pm
iirc they are all VSV's the brown ones for the homologated anti lag and the blue for WI, but i'am not sure.....
have anyone a picture of the group a water injection pump?
PostPosted: Sat Jan 22, 2011 1:55 pm
the VSV on the left (blue / green) is the Tvsv, nothing to do with WI
Sunny is right for the right one, fresh air related.
and the blue pot is a vaccum tank, this tank is also on the 185, it keeps Tvis close even if we have boost before 4500+
PostPosted: Tue Jan 25, 2011 9:07 pm
if anyone see a group a spec ST205 anytime, could you do some pictures from the water injection pump or possible ask for the typ of pump for me
many thanks :)
the issue is to find a small compact pump that can do the job, but it should can hande a cyccle like the fuel injection
PostPosted: Thu Feb 17, 2011 1:16 pm
IIRC the pump in the TTE catalogue/parts manual was a 120psi one......will have to check at some point.
John
PostPosted: Sun Nov 06, 2011 5:59 pm
Hi folks,
in hope that i'am allowed to drop another question,
is is about the A/C idle up valve on our strees ST205, what does this connection on a TTE ST205 do?
here i have a pic where it is no used
PostPosted: Sun Aug 12, 2012 7:34 pm
does anyone know where i can such plugs for the intake manifold?
they are 1/8BSP
PostPosted: Sun Aug 12, 2012 9:18 pm
Think Auto will stock something very similar.
PostPosted: Mon Aug 13, 2012 10:23 am
thanks, i contacted them :)
