http://gt4dc.co.uk/forum/
Done the cam belt but....
http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=5695
Author:  banzaibaz [ Sun Jun 10, 2012 9:29 am ]
Post subject:  Done the cam belt but....
I noticed from following the guide on here that my cams did not have the cut outs that align with end caps this wasnt a problem as i just went back to basics i was just wondering do some have them and some not ?
Author:  two_OH_five [ Sun Jun 10, 2012 10:37 am ]
OEM cams?
Author:  banzaibaz [ Sun Jun 10, 2012 7:02 pm ]
what oem cams have them or not ?
Author:  Kris [ Sun Jun 10, 2012 9:27 pm ]
OEM cams have the cut outs
Author:  banzaibaz [ Mon Jun 11, 2012 5:52 am ]
Oh right cheers for clearing that up kris well these where the originals that came in it from japan but i did not see any makers names on them just some numbers i will dig a little further..
Author:  Kris [ Mon Jun 11, 2012 8:41 pm ]
Stock 205 cams and gears...
Author:  Welshman [ Tue Jun 12, 2012 2:21 pm ]
some oem cams do not have cut outs ive seen a couple they have half the metal on the wide part of the cam too .
i think they could be later cams but no cut outs doesnt automaticly mean performance ones .
idealy you should determin they are on the marks before you take them off and mark them yourself for future referrence ;)
Author:  banzaibaz [ Tue Jun 12, 2012 5:19 pm ]
Yeah they are not the same as that kris even the nut parts look different, i just used the existing set up as a base and set the the hks gears both to zero marked everything up and replaced alike i even made a twin cam locking tool that locked both the 24mm nuts that are built in to the shafts which sat at diff positions to each other i did have a bit of trouble trying to get the crank pulley off my 500nm gun wouldnt budge it so i made a tool and used a 4ft 1" dr breaker ill add the pics of what i mean to my build thread cheers for the help i seem to be absolutely useless at researching on ta web :?
Author:  two_OH_five [ Tue Jun 12, 2012 6:45 pm ]
Have a rummage around in my st215 rebuild thread. You'll find pictures of st215/gen4 cams and the OEM cam numbers are in there too IIRC
Author:  banzaibaz [ Tue Jun 12, 2012 8:01 pm ]
That was a good heads up i enjoyed that read alot and a lot of things looked familiar i think what i will do is the rocker has to come back off so i will get some pics to divulge over,that did look like a one off good bay deal.
