It is currently Tue Oct 07, 2025 6:20 am
PostPosted: Sun Dec 11, 2011 10:03 pm
Hi folks,
i'am a little bit bored today so i though to descript what i had found on the late spec 3S-GTE and Beams oil pump
here is a picture from a gen.3 pump (thanks again Kris)
part number: 15100-88460
except the crank position sensor, there is a difference on the backside at the outro which is also slightly different on the frontside
part number: 15100-88561
unfrotunetly i doesn'T want to open the well touqued housing to measure the rotors, but in front of outter measurement i doesn't found a difference
against the older gen.3 style gen.4 pump
the gen.4 pump uses the bigger gen.2 pump gear which i think is becouse of economy, i will go with the smaller gen.3 one to raise the flow rate (and pressure)
i'am told from redtop drivers that the oil pressure with the late spec pump higher against gen.3, unfortunetly i doesn't remember the value any more :oops:
and next on the list is the water pump and his housing, last weekend i found that my plastik impeller gen.3 water pump doesn't fit the housing and noticed that the pump seat is different
part number of gen.3 plastik impeller pump : 16110-79125
you see the the pump fit even there is no gasket used
and here you see the pump doesn't fit the housing, normally a terrible problem, but if you want to create a uprated pump a very fine situation
i will give the gen.4 housing a new impeller seat with 0mm clearance (without gasket), a used gasket has 0,5mm which give me the minimum clearance i need, this is a reduction of ~1,5mm axial clearance and raises the efficiency (flow), former test with a stainless impeller pump shows 23% more flow but this value is not accurate negotiable to the plastic impeller
also note that the plastic impeller has a better design which give also a raised flow
hope you doens't found this to boring, and possible it gives you further ideas to you project :)
PostPosted: Mon Dec 12, 2011 10:18 pm
Car Model: ST165
As i understand, the gen 4 water pump impeller is a metal "water agitator" like that of the gen 2 (ST185)...
have you got a picture to illustrate ?
ST165 turbo 4WD
PostPosted: Tue Dec 13, 2011 3:07 pm
Hi Gary,
in general there are two types of impellers available, one in stainless and one in platic (with a better design)
unfortunetly, i do no have a gen.4 pump any more, and yes my gen.4 pump was the stainless impeller one (also used on gen.3)
i come to the conclusion that the gen.4 pump and housing works with less axial clearance which raises the efficiency and output of the pump, but males it not accepable for the plastic impeller
have a look to this for more informations
http://www.gt4dc.co.uk/forum/viewtopic. ... mp+upgrade
in principle this is what toyota did to the gen.4 pump but the other way -> pump seat
decking like i did is no good way becouse the alu threads are not strong enough any more
PostPosted: Tue Dec 13, 2011 7:21 pm
gen3 impeller is plastic, i serviced enought to be sure.
PostPosted: Tue Dec 13, 2011 10:28 pm
i think both are used, my r&d pump was a stainless one and definetly from a gen.3
PostPosted: Tue Dec 13, 2011 11:22 pm
from 9402 to 9908 toyota only offer the plastic one for ST205.
But for a ST202 there it's a metalic one.
or perhaps you have a generic one from aisin, possible?
PostPosted: Wed Dec 14, 2011 7:07 pm
Hi
thats a good point, the pump i had was dated at 94/8, without part number on it
after a quick toyodiy part number comparison it looks like you are right, ST202, ST215, ST246 uses the same part number except ST205
PostPosted: Fri Jan 20, 2012 11:34 pm
Hi folks,
just a few datas that possible help
oil pump 15100-88561 (4th gen GTE and beams redtop) with ST205 pump gear is calculated
5,4L/min per 1000rpm
today i ordered a beams blacktop pump to get a calculating too, we will see what kind of OEM pump flows the most
PostPosted: Fri Jan 27, 2012 5:17 pm
Beam black top oil pump is calculated, and i found a +10% in flow with
5,95L/min per 1000rpm
slightly different gerotor shape and +1,5mm in thickness
this is the highes flow in the 3S series i found on gen.3 and upward and fully plug&play to a gen.4 to the gen.3 just if you also use the gen.4 alu-oilpan
on picture nr.2 you can see a further revision, this time to the pump inlet
PostPosted: Mon Jun 11, 2012 9:28 pm
correction to the beams oil pump, she isn't plug&play, i had to grind the block a little bit to make her fit, sorry i have no picture available but was nothing dramatically
