http://gt4dc.co.uk/forum/
pedal box/bias install do`s and dont`s
http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=5690
Author:  banzaibaz [ Sat Jun 09, 2012 11:14 pm ]
Post subject:  pedal box/bias install do`s and dont`s
Im going down the titan pedal box route and was wondering if its as easy as it seems to be ive removed the abs(205) left the rear hard pipes up to the bulk head and do i just link up one slave on the pedal box to the 2 lines (rear) and same for the front with braided flex lines or hard pipes then flex lines and do i need anything else in line??
Author:  Nibbles [ Sat Jun 09, 2012 11:57 pm ]
Only use flexi where needed for moving parts (i.e. where already fitted as standard).
Link the 2 rear pipes into a T piece fed from one master cylinder outlet. Link the 2 front pipes with a T piece to the other master cylinder outlet.
Easiest/best pipe to use is kunifer or failing that copper. These can be flared with one of the cheap tools that is easy to use in situ.
Author:  TrackToyFour [ Sun Jun 10, 2012 12:17 am ]
Titan pedal box? Can't find that. Do you mean Tilton?
Author:  banzaibaz [ Sun Jun 10, 2012 9:20 am ]
Sorry don that was me being up late yes tilton lol and thanks nibbles exactly what i was thinking of doing.
Author:  banzaibaz [ Sun Jun 10, 2012 7:10 pm ]
ok been doing some research on this but for the life of me cant/dont get what i need to connect to the hard pipes i know either a 3 way or 4way for brake light pressure switch T piece (front) i have already got a load of dash 3 and dash 4 s/s flexi but they have the normal female ends with concave inside and the pipes have the male ends but the end of the brake line has also a concave to it can some one clarify this for me
Author:  Nibbles [ Mon Jun 11, 2012 11:57 am ]
Not sure if this is the info you're looking for.
http://www.mig-welding.co.uk/forum/show ... php?t=4522
As regarding whether you need a dished end, look inside the fitting and see if it has a point sticking up to go in a dished end. I normally just do the single flare anyway and let the point make it's own dish as the nut tightens down.
Beware, the cheap flaring tools can't cope with the standard steel pipe so either bend the standard pipes so the ends go straight into a T piece or you'll need to run new pipes back to the next joint.
T piece (can't remember whether celica is metric or imperial) You can re-use the screw in parts from the pipes you remove if you wish.
http://www.ebay.co.uk/itm/IMPERIAL-BRAK ... 1e6eadcb7a
or
http://www.ebay.co.uk/itm/METRIC-BRAKE- ... 2ebed545a1
Your local factors should sell kunifer or copper brake pipe. (Mine only sells copper). Ensure the pipe is well supported so it can't vibrate, especially with copper.
Author:  two_OH_five [ Mon Jun 11, 2012 1:12 pm ]
Gender Benders
If you need a male end but have a female you just use one of these
And Vice versa
Author:  banzaibaz [ Mon Jun 11, 2012 8:16 pm ]
This is great Guys thanks a lot...
Author:  banzaibaz [ Sun Jun 17, 2012 7:42 pm ]
Ok so the slave side of things on the ped box pressure/out is 3/8 unf x24 tpi and i think the ST205 is 10mmx1 metric, are most hard pipes on cars a standard size O/D so i can join up with diff fittings or shall i just re do the hard pipes from scratch in copper ??
Author:  Nibbles [ Sun Jun 17, 2012 10:25 pm ]
Standard size is 3/16 (4.76mm) which works fine with the standard celica fittings.
