It is currently Mon May 13, 2024 6:00 am
 Post subject: Oil temperature plate
PostPosted: Tue May 29, 2012 9:17 am
What size plate do I need to fit inbetween the filter and block so I can run oil temperature gauge off it?
1998 mercedes E280- sold
PostPosted: Tue May 29, 2012 11:04 am
http://www.ebay.co.uk/itm/MR2-SUPRA-CEL ... 5d33c5b3c4
Something like this ?
2004 Subaru WRX
PostPosted: Tue May 29, 2012 12:04 pm
I don't think it matters too much as long as you don't have a 185 (I may be wrong but isn't there a space/width limitation?).
Just look for a plate that has a 3/4UNF thread adapter/thread on it and it should be fine. :)
PostPosted: Tue May 29, 2012 12:11 pm
Thats the thing homer. I have 185 so is there difference between 205?
PostPosted: Tue May 29, 2012 1:31 pm
ST205 oil filter is in a different place, on the ST185 there probably inst room for a sandwich plate between the filter and the oil cooler donut.
I would look at measuring the oil temp in the sump.
PostPosted: Tue May 29, 2012 6:55 pm
Yep, sump oil temp is the best overall location. If that's awkward then you could always take a T piece off the oil pressure sensor in the head assuming its the same as an ST205?
PostPosted: Tue May 29, 2012 7:01 pm
My oil pressure sensor comes off the top right hand of the block, I don't know if thats the same as 205.
To go via the sump, is there a special bolt that acts as plug and sensor adaptor, or do you have to drill new hole and fit sensor that way?
PostPosted: Tue May 29, 2012 10:59 pm
I can't really remember the st185 sump too much. Ideally you'd have a hole cut and a nut welded on which you would other screw the sensor into.
You can also use the sump plug hole if you can make the sensor fit, you need to make sure the wire doesn't get twisted up when tightening or untightening the sensor to change the oil.
PostPosted: Tue May 29, 2012 11:01 pm
That's the awkward bit I was referring to :twisted:
PostPosted: Tue May 29, 2012 11:08 pm
I don't remember a lack of height problem on the 185 oil filter, just that it was next to the downpipe and therefore suffered extra oil heating. I'll have another look next time I see a 185 engine complete.
Drilling a hole in the sump and welding on a nut requires sump removal, both to get rid of swarf and to avoid an oil fire.
I'm sure it's possible to drill & tap a hole in a sump plug - there may even be something available. The 2 downsides are that the back of the sensor may stick down a bit and take a battering, plus sump plug removal will be a pain with wires hanging off (a plug will avoid wire twisting problem).
PostPosted: Wed May 30, 2012 9:37 am
Ok thanks for advice. I'll have a look into it.
PostPosted: Fri Jun 22, 2012 10:22 am
Can even get an oil filter relocation kit and they have pre drilled holes for sensors.
Now oil filter is away from heat source - downpipe, and you can fit your required oil sensors too.
98 Celica GT4 ST205
Full forged rebuild with Wiesco pistons, Crower rods, mildly ported head, 264/272 HKS cams, FMIC, PFC Pro, GT35 BB turbo, turbo back 3" system.
Currently running 1.6bar/520+bhp
