It is currently Sun May 12, 2024 6:07 am
PostPosted: Sat Mar 24, 2012 9:36 pm
I need to get my Toda R cams fitted so i can get the ST205 back up and running but are they plug and play as so to speak or will i need to do the shims (I=264 E=264) any help or links would be very helpful, oh im going to be running on new OE springs due to the slight difference compared to stock thanks Bazza.
PostPosted: Sat Mar 24, 2012 9:52 pm
you definetly have to measure the clearance and correct it if it is out of tolerance
PostPosted: Sun Mar 25, 2012 11:23 am
As Sunny says - you will need to change the shims - also check that you don't get "coil bind" with these cams i.e. you can turn the camshaft without the spring coils touching each other
PostPosted: Fri Mar 30, 2012 11:05 am
Does anyone local to me with knowledgeable know how to do this fancy helping to get this part of the job going i have all the tools necessary to do this job but dont really want to do it wrong hence the help, two heads and all that the engine is stripped down to the cams belt is still on so its just a mater of going through the shim clearances, free food and drink on offer thanks Bazza.
PostPosted: Fri Mar 30, 2012 2:23 pm
just ask your local toyota dealer, iirc my head was ~200-250€
i want to do it myself but had the problem that no shim fits any more (doesn't closed the valve any more in front of the machined valve seats and custom cams), so it was the cheaper way for me instead to buy a useless set of shims just to measure the correct ones
geetz
