It is currently Thu May 23, 2024 2:49 am
PostPosted: Wed Feb 01, 2012 7:42 pm
Hi folks,
as in the topic, has anyone good ideas about to get the rust as good as possible out of the bare block?
i'am glad for any tips & tricks :)
PostPosted: Thu Feb 02, 2012 12:05 pm
http://www.instructables.com/id/Electro ... aka-Magic/
DIY at home :)
PostPosted: Thu Feb 02, 2012 2:38 pm
I have experimented with this method and it is good however it does require a certain amount of 'line of sight' unless you can somehow suspend an electrode inside the block without touching anything it will struggle to be effective at cleaning the inside.
PostPosted: Sat Feb 04, 2012 5:44 pm
looks like a good way but to complex for the block like sirius said
isn't there any resistor used to protect against short circuit?
i could built a wood plate with a few electrodes that goes in the block cooling bores, i could give this method a try :)
PostPosted: Tue Feb 07, 2012 3:26 pm
Hi folks,
i decided to to give a more easier method a try, so i bought some phosphor acid
possible anyone who also used this merhod can give me advises?
PostPosted: Sun Feb 12, 2012 1:28 pm
job done, works perfect
i decided to use a 15% acid for ~6hours, here some pictures
