It is currently Fri May 10, 2024 7:55 pm
PostPosted: Sun Jan 22, 2012 6:08 pm
When I first got this ECU I put it in my car and the car wouldn't start it would turn over but not fire so I took it out and tryed it in Friends car and first turn of the key it fired up and ran fine so I thought I would give it anouther go in mine, and same thing happend again it would turn over but no fire I have checked for error codes and it shows number 12 RPM signal fault - No G1,G2 or NE signal to ECU. I have checked all the wires they seem fine and my standard ECU works perfect showing no error codes has one got any ideas what I could be?
The ECU is a E.L prototype
Wich removes fuel cut, 112 speed limit and rev limiter
And has a different map on it.
My car is a ST185 JDM 1992
PostPosted: Sun Jan 22, 2012 7:30 pm
What year is your friends car ?
I'm thinking this ecu is maybe for the earlier 185 model 89-91 :?.
2004 Subaru WRX
PostPosted: Sun Jan 22, 2012 9:30 pm
There are a number of different pinouts on the various gen2 3sgte ecu's. One variant has the dizzy signals in a different place, this just happens to be the verion in my 1990JDM.
The following has some useful information about the standard ECU.
http://www.cdd.co.uk/stuff/standard_ECU.pdf
You can work out which pinout by checking the wire colours in the loom against position in the plugs.
PostPosted: Mon Jan 23, 2012 6:56 pm
It is most likely that it could be that the ECU is for the wrong year/pinout config as has been suggested or....
IIRC the standard ECU will still run and not show a fault code with quite major issues with camshaft sensor inputs. I have had this once where an Apexi Power Fc would not a run a ST205 and yet standard ECU would. After lots of time and head banging it became apparent that the cam sensor was only outputting a single signal not all three of G1,G2 or NE.
PostPosted: Mon Jan 23, 2012 8:49 pm
Right guys i managed to sort it now the ECU I was trying is from a early 185 so that's why it's not workin I should have checked the part numbers befor I bought it :(
Thanks for all the help
PostPosted: Tue Jan 24, 2012 9:05 am
You should be able to repin it and get it working now you know you can ind the differences...
PostPosted: Tue Jan 24, 2012 12:51 pm
yeah im going to try makeing up a new loom to go between, i think that sounds easyer than re-pin it :) but i maybe be proven wrong lol
