It is currently Sun Apr 28, 2024 9:01 pm
PostPosted: Wed Jan 18, 2012 10:21 pm
The time is nearly here for when i will be fitting the rmr side feed but on further inspection i would like some input on air temp sensor location ive decided to go with the riat type as opposed to the standard ST205 sensor and noticed this is fitted quite central in between flow on the OE intake and the rmr intake has 5 threaded holes @ the opposite end to the T/B (above cam belt) and would of thought this is not going to be as accurate as being in the flow would any one like to comment on this ie would i be better off relocating to a similar position to standard ? ?
Users browsing this forum: No registered users and 125 guests
