It is currently Sun Jun 16, 2024 9:41 am
PostPosted: Thu Jan 12, 2006 1:12 pm
Just found this product http://www.junack.com/intelligent.html
Looks like it does the sensor monitoring all on one screen too (Third pic down on the right)
What you think guy's 'n' gal's??
ST205 WRC #0002249
PostPosted: Thu Jan 12, 2006 2:49 pm
Looks very similar to the Blitz i-Color. Would need to take a closer look to compare the two. It would be interesting to hear what stevo_st24 thinks!
PostPosted: Sat Jan 14, 2006 4:47 pm
It's not an i-Color a-like
It's purely an information display not a combined ebc
It also appears to be connected into a diagnostic ECU port (I assume OBDII) a la Blitz R-Vit
More (translated) info her
http://translate.google.com/translate?h ... meter.html
PostPosted: Mon Jan 16, 2006 4:03 pm
I’m thinking of upgrading my SBC iDIII to an i-Colour number for monitoring my Oil temp & pressure, I take it you have one Stevo?? Is it worth the 300 notes for the upgrade??
(Damn ODBII gets you everytime!! :( :( )
ST205 WRC #0002249
PostPosted: Mon Jan 16, 2006 7:46 pm
TBH I'm not sure
It's a nice piece of kit and it does provide good information
My only concern is that for something like oil pressure the display might be a little limited
It's not particularly high contrast and in bright sun it can be difficult to read
Personally I want to see engine vitals like oil temp and pressure in big bold easy to read displays so I can see trouble coming
That said you can set alarm parameters on the Blitz so it will at least warn you in advance
Overall I'd say it's probably worth it if you want to try and clean up but it's not really up to scratch for a serious race/strip machine
It's for this reason I have the Defi kit for vitals and will use the Blitz for "interesting" but not critical stuff like c/cooler water temp, cooling system pressure etc
BTW, you can upgrade the SBC-iD by just buying the MMC-iColor and using your existing solenoid/sensors :wink:
PostPosted: Tue Jan 17, 2006 9:05 am
Cheers for that Stevo might have to look into the Defi bits then.
Can I just say that that swearing filter is very sensitive!!!! :shock: :shock:
I only said D a m n & it's made me out to be a criminal!!!! :lol: :lol:
ST205 WRC #0002249
