St185 GT4 Aerial http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=2859 |
Author: | Exup [ Fri Mar 20, 2009 10:31 pm ] |
Post subject: | St185 GT4 Aerial |
Can anyone please tell me how to get my electric aerial to work, i know that it will go up & down, (tested it) but im now aware that it works in conjunction with the ignition and passes a signal to a relay, unfortunately most of the original wiring that worked it from the head unit has been cut up by the previous owner. |
Author: | DeeCee [ Mon Mar 30, 2009 3:05 am ] |
JDM Celica Wiring 12V + = Blue w/Yellow stripe Ignition = Grey Ilumination = Green Ground = Brown Aerial = Pink + Black w/red stripe L front = Pink+ / Purple - R front = light green+ / blue- L rear = black+ / yellow- R rear = red+ / white- Note - aerial is combination of Pink wire twisted together with Black w/ red stripe connected to aerial output from headunit (normallly blue w/ white stripe) |
Author: | Exup [ Mon Mar 30, 2009 10:58 am ] |
I had a look @ it yesterday and got the radio to work, but the aerial wouldn't go up. With regards the aerial colours i will check them today. Cheers for help. DeeCee wrote: JDM Celica Wiring
Author: | Exup [ Thu Apr 02, 2009 8:29 pm ] |
Aerial wont go up, lost my patience now, but the radio and cd player work. As soon as i have more funds, i will let somebody else check fix the problem. Cheers for your help guys. ![]() |
Author: | DeeCee [ Sun Apr 05, 2009 3:33 am ] |
you did put the pink and black/red together onto the remote output on the headunit? Or were you using loom adaptors? because it would have done it for you. |
Author: | Exup [ Sun Apr 05, 2009 11:02 am ] |
Im going to buy some scotch locks, i will have another go. DeeCee wrote: you did put the pink and black/red together onto the remote output on the headunit?
Author: | DeeCee [ Mon Apr 06, 2009 12:23 am ] |
hard to get two pieces of wire into a scotch lock. Get a terminal strip. Nothing wrong with them and they are easy to use ![]() ![]() |
Author: | Exup [ Mon Apr 06, 2009 8:57 pm ] |
Still cant get the aerial to work. I think it's time someone else had a go, but @ a later date. Thanks for your help. ![]() DeeCee wrote: hard to get two pieces of wire into a scotch lock.
