http://gt4dc.co.uk/forum/
ST205 ECU Pin Out Diagram
http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=2834
Author:  Muddy Water [ Thu Mar 05, 2009 1:19 pm ]
Post subject:  ST205 ECU Pin Out Diagram
Does anyone have access to a JDM ST205 ECU Pin Out Diagram?
Trying to locate the Speed Sensor wire out the back of the ECU so that I can wire in my Turbo Timer.
Thanks.
Author:  Diceman [ Thu Mar 05, 2009 2:40 pm ]
Thanks to "bigger Kris" @ Gt fours for the info.
Author:  Muddy Water [ Thu Mar 05, 2009 11:27 pm ]
Thanks for that.
OK so the Speed Sensor wire out the back of the ECU is SP1 but do you happen to know what colour it is?
Author:  Sirius [ Fri Mar 06, 2009 12:01 am ]
Just look at the ECU and count the wires - right hand plug top row third wire in from the left is the one. :)
Author:  Diceman [ Fri Mar 06, 2009 10:28 am ]
Colours are irrelevant to me I am afraid.
Author:  TrackToyFour [ Fri Mar 06, 2009 2:35 pm ]
Must be a bit challenging on the wiring front. Can you see stripes or differences in solid colour?
Author:  Diceman [ Fri Mar 06, 2009 3:04 pm ]
I can see that there are colours and sometimes stripes but not what actual colour they are.
DTA install is gonna be fun :-)
Author:  Muddy Water [ Fri Mar 06, 2009 7:15 pm ]
Thanks for everyones help 8)
I sorted it today :D
Speed Sensor wire = SP1 = As you look at the ECU from behind, it's the right hand plug, top row, third wire in from the left = Orange.
Author:  TrackToyFour [ Fri Mar 06, 2009 11:27 pm ]
How did you actually connect the turbo timer wire to the orange speed sensor wire...solder, scotch block etc?
Author:  Muddy Water [ Sat Mar 07, 2009 10:04 am ]
The Turbo Timer loom comes with a purple lead that has male & female insulated bullet connectors - the best way of describing the wire arrangment is it looks like a 'y'.
I just cut the orange wire and installed (crimped) some male & female insulated bullet connectors and then plug'n'play.
