It is currently Sun Oct 05, 2025 12:18 pm
 Post subject: St185 GT4 Aerial
PostPosted: Fri Mar 20, 2009 10:31 pm
Can anyone please tell me how to get my electric aerial to work, i know that it will go up & down, (tested it) but im now aware that it works in conjunction with the ignition and passes a signal to a relay, unfortunately most of the original wiring that worked it from the head unit has been cut up by the previous owner.
Exup
PostPosted: Mon Mar 30, 2009 3:05 am
JDM Celica Wiring
12V + = Blue w/Yellow stripe
Ignition = Grey
Ilumination = Green
Ground = Brown
Aerial = Pink + Black w/red stripe
L front = Pink+ / Purple -
R front = light green+ / blue-
L rear = black+ / yellow-
R rear = red+ / white-
Note - aerial is combination of Pink wire twisted together with Black w/ red stripe connected to aerial output from headunit (normallly blue w/ white stripe)
GT Four Adovansu
PostPosted: Mon Mar 30, 2009 10:58 am
I had a look @ it yesterday and got the radio to work, but the aerial wouldn't go up.
With regards the aerial colours i will check them today.
Cheers for help.
DeeCee wrote:
JDM Celica Wiring
Ignition = Grey
Ilumination = Green
Ground = Brown
Exup
PostPosted: Thu Apr 02, 2009 8:29 pm
Aerial wont go up, lost my patience now, but the radio and cd player work.
As soon as i have more funds, i will let somebody else check fix the problem.
Cheers for your help guys. :wink:
Exup
PostPosted: Sun Apr 05, 2009 3:33 am
you did put the pink and black/red together onto the remote output on the headunit?
Or were you using loom adaptors? because it would have done it for you.
GT Four Adovansu
PostPosted: Sun Apr 05, 2009 11:02 am
Im going to buy some scotch locks, i will have another go.
Exup
PostPosted: Mon Apr 06, 2009 12:23 am
hard to get two pieces of wire into a scotch lock.
Get a terminal strip. Nothing wrong with them and they are easy to use :)
GT Four Adovansu
PostPosted: Mon Apr 06, 2009 8:57 pm
Still cant get the aerial to work.
I think it's time someone else had a go, but @ a later date.
Thanks for your help. :wink:
Exup
