It is currently Mon Oct 06, 2025 11:19 pm
PostPosted: Fri Jun 27, 2008 4:41 am
Could some of your w/ st205 check something for me. When the IC pump is running, and you take the cap off the WTA core, does the water create a spinning whirlpool, or does it just move.
I am curious since i hooked mine up.
When I first set it up w/ the electric pump, the water whirled in a vortex, but after I redid everything it just moves. So I am unsure if the water is moving in the right direction.
thanks,
JC
Coldiron (Cold - Iron)
http://www.noritoy.com
PostPosted: Fri Jun 27, 2008 7:58 pm
Yeap same on my failure box, small swill pool inside nothing major.
lower CC pipe closest to bulkhead goes to pump IN, end of pump case center of vain.
