http://gt4dc.co.uk/forum/
Total replacement of stock hoses under the bonnet of 205?
http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=2096
Page 1 of 2
Author:  Prochorus familiaris [ Sun Oct 28, 2007 9:48 am ]
Post subject:  Total replacement of stock hoses under the bonnet of 205?
Hi all,
Who knows - what are the sizes (inner our outer diameter, mm) of hoses, which are utilised in ST205 (under the bonnet)?
(Radiator hoses & metal hoses are out of request, all other are wanted 8) )
Correct me if I'm wrong - there are 4 types:
- 4 mm
- 6 mm
- 8 mm
- 16 mm
Plus:
what hoses are untouchable for being substituted with Samco's stuff?
I've heard, that Samco's stuff are suitable with some exceptions..
- i.e. Samco's aren't stable while working with some chemical substances..
Author:  Kris [ Sun Oct 28, 2007 12:24 pm ]
Any pressure line e.g. FPR wastegate actuator should ONLY be replaced with hoses designed to hold pressure i.e. not the Samco vacuum hose that is commonly used
Author:  Prochorus familiaris [ Sun Oct 28, 2007 1:21 pm ]
Huh, Kris,
It's clear definitely - these ones will be happy to meet Aeroquip stuff..
Author:  Prochorus familiaris [ Sun Oct 28, 2007 1:43 pm ]
Kris, BTW,
Would you be so kind to give a hint - what are the pressure-holding hoses - all the list?
So, from now on:
1) FPR hose
2) Wastegate actuator hose
3) ???
4) ???
Also it will be a nice turn for all clubbers to know brands & part. no.'s of hoses, which could be used as a substitutes for stock pressure-holding ones - i.e. for FPR hose replacement, for WG actuator hose replacement...
Aeroquip???
Thanks in advance.
Author:  Kris [ Sun Oct 28, 2007 2:56 pm ]
I suppose pretty much all of the hoses are holding pressure since the engine uses a turbo.
I mention the above ones as on the 205 it doesn't matter if the other hoses fail, it'll just be an air leak, whereas if the FPR or wastegate hoses fail then a whole world of pain is just around the corner :)
It seems quite common to replace all the rest of the air hoses with samco vacuum hose.
Other areas I would pay attention to would be particular hoses that come into contact with oil or oil mist such as turbo hoses and air intake, these need to be lined to help them resist breaking down due to the oil.
The turbo outlet hose may also be another to look closer at since this muct resist pretty high temps say 150C minimum
Maybe it would be easier to just leave the stock air lines etc in place? :lol: But it doesn't look as pretty! :lol:
Author:  Diceman [ Sun Oct 28, 2007 3:41 pm ]
Agree with Kris. After havinga samco hose (unbraided) split on my St185 and suddenly had 1.7 bar and rising!
Don't do it m8. Get proper braided hose - Maybe metal braided if you wnat to do it properly.
Author:  Prochorus familiaris [ Sun Oct 28, 2007 4:29 pm ]
Aha..
So, thanks..
What I'll do:
Super-duper investigation for splitting all the hoses into 2 groups:
1) Air carriers
2) Liquid carriers
Then group #1 will be devided onto 2 subgroups:
1a) carrying HP air
1b) carrying LP air
Then group #2 will be devided onto 3 subgroups:
2a) carrying non-dangerous & surrounded with no fallouts of dangerous LP liquids
2b) carrying & surrounded with fallouts of dangerous LP liquids
2c) carrying non-dangerous HP liquids
2d) --//--//- dangerous HP liquids
Samco could be used for:
1b, 2a
Metallic hoses could be used for:
1a, 2b, 2c, 2d
Will try to post a report on it..
Author:  Jamie_F [ Sun Oct 28, 2007 8:06 pm ]
all of my vac hoses are replaced with samco/sard vac hose, been on there for about 10 months now with no issues, i do check all the hoses over every now and then, never had to replace one or found any splits yet.
Author:  TrackToyFour [ Sun Oct 28, 2007 8:59 pm ]
Fluoro-silicon lined hoses are resistant to oil but are expensive to produce so most commonly available after-market silicone hoses don't have this lining :(
I've recently been running a temperature sensor in the post-compressor, pre-intercooler hose and this has shown temperatures of up to 75C under brief periods of acceleration. My engine is essentially unmodified (apart from a hybrid turbo). Modified 3S-GTE's probably see higher temps.
Author:  Prochorus familiaris [ Mon Oct 29, 2007 5:56 am ]
Aha..
So, all is up to logics. As usual.
Author:  Prochorus familiaris [ Sun Nov 11, 2007 8:12 pm ]
Mates,
Who can give me the sizes (dia) for those hoses, which are reasonable to be replaced with silicone ones?
Author:  Sirius [ Tue Nov 13, 2007 8:37 am ]
With using metal braided hose you may also want to consider the issue of abrasion - the metal will rub through any silicon or rubber lines its touching in a pretty short amount of time.
Author:  Prochorus familiaris [ Tue Nov 13, 2007 3:47 pm ]
Ok, as I see - nothing concrete.
As usual.
Author:  Jamie_F [ Wed Nov 14, 2007 2:36 pm ]
i got a 3m length of 4,5 and 6mm internal samco hoses, did every vac hose in the bay with some to spare.
Author:  two_OH_five [ Wed Nov 14, 2007 4:10 pm ]
I tend to agree with Kris' approach
Keep mission critical stuff in aeroquip/braided/fuel line
This I would consider, like Kris
FPR to inlet manifold
Turbo to wastegate actuator and from there to any boost control mechanism
Inlet manifold to MAP sensor
Anything else will fail safe, these will not
I keep meaning to tidy up the maze under the bonnett but every time I look at it I loose heart
