It is currently Mon Oct 06, 2025 4:09 pm
Post new topic Reply to topic  [ 116 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
 Post subject: Re: Developing an ecu ?
PostPosted: Wed Jan 23, 2013 3:50 pm
Postman's just been, it's Christmas again :)
PostPosted: Wed Jan 23, 2013 10:34 pm
Goddamn surface mount !!!!!!!!!!!!!!!! ^^^E£*&*(W^W&&W*"£*("(
Trying to nudge the little chip into position with a screwdriver. Anyone heard of tiddlywinks ?
PostPosted: Thu Jan 24, 2013 12:15 am
Sounds like a break and a cup of tea is in order! :)
PostPosted: Thu Jan 24, 2013 12:50 am
Built as far as possible minus the bits I thought I had in stock but can't find.
The surface mount was a pain, especially the 6 pin one as it's only about 2mm x 3mm so difficult to get hold of and easy to move accidentally (or flick across the bench :lol: ) Maybe once I've built a few I'll get the hang of it.
I'll keep tabs on this post of errors / design changes to include for the next batch of boards.
Spotted before I even got the boards back:
Knock chip has no crystal / clock connected. Link Xin to PIC18 Xout & use external 10MHz clock.
Add programming header for dsPIC. (removed as unnecessary as chips only need programming once. Since discovered my standalone programmer won't handle this version)
Spotted on assembly:
IC4 out of line with rest of transistors in the row.
Add fixings in case I decide to make an achoring strip / heatsink. (I'm nervous about standing power transistors unsupported if there's vibration, though it's done in the standard ECU).
Add fixing for USB sub-board rather than relying on glue.
Look again at part No.s for the D connectors so I get 2 matched and WITH fixing screws. The RS catalogue is awful.
No input capacitor in IC6. / No decoupling capacitors on 12V rail. (not an issue yet)
Spotted on debugging.
Reset on dspic is tied to 5V via network, should be 3.5V. (happened when voltage for PIC18 changed to 5, didn't notice link to dspic)
Self protecting transistors limit at about 3A with 3.5V gate drive. Change injector drives to conventional logic level mosfet. STP60NF06L
Rather a lot of errors, including some real schoolboy ones. Symptom of working in short bursts in spare time.
PostPosted: Thu Jan 24, 2013 1:56 am
You running Clint's car on it yet?? :lol:
PostPosted: Fri Jan 25, 2013 6:40 pm
So far so good :)
programming header spliced in so I can program the dspic with the pickit programmer. (Only need to this this on one as I can program the chips for others in this board).
Command line compiler purchased. $250 ouch. This translates the source code in 'C' to the machine code run by the chip.
Noddy program written (along the lines of 10 print "hello world", 20 goto 10 :lol: ). In this case set the pins to input & output correctly, then invert the INJ4 line each time round the loop with a delay in between.
Result above.
For those interested, the source code used:
#device dspic33FJ128GP802
#FUSES NOPROTECT,NOIESO,PR_PLL,NOOSCIO,HS,WDT,WINDIS,ALTI2C
typedef int16 word; // word is unsigned int
typedef int16 uword; // uword is unsigned int
typedef signed int16 sword; // sword is signed int
typedef char uchar; // uchar is unsigned char
typedef signed int8 schar; // schar is signed char
//ports
#word TRISA = 0x02C0
#word PORTA = 0x02C2
#word LATA = 0x02C4
#word ODCA = 0x02C6
#word TRISB = 0x02C8
#word PORTB = 0x02CA
#word LATB = 0x02CC
#word ODCB = 0x02CE
void main(void)
uword itmp;
// powerup / reset initialisation
PORTA = 0;
PORTB = 0;
// main loop
while (1)
// each loop initialisation
#asm
CLRWDT
#endasm
TRISA = 0xFFEF; // set i/o pins
ODCA = 0;
TRISB = 0x2477;
ODCB = 0x0060;
PORTB ^= 0x0200;
for (itmp = 0;itmp < 10000;itmp++);
The output code produced by the compiler (in readable form)
.................... void main(void)
00200: BSET.B 81.7
00202: SETM 32C
00204: MOV #3F80,W15
00206: MOV #3FFF,W0
00208: MOV W0,20
0020A: NOP
0020C: MOV #3F80,W15
0020E: MOV #3FFF,W0
00210: MOV W0,20
00212: NOP
.................... uword itmp;
.................... // powerup / reset initialisation
.................... PORTA = 0;
00214: CLR 2C2
.................... PORTB = 0;
00216: CLR 2CA
.................... // main loop
.................... while (1)
.................... // each loop initialisation
.................... #asm
.................... CLRWDT
00218: CLRWDT
.................... #endasm
.................... TRISA = 0xFFEF; // set i/o pins
0021A: MOV #FFEF,W4
0021C: MOV W4,2C0
.................... ODCA = 0;
0021E: CLR 2C6
.................... TRISB = 0x2477;
00220: MOV #2477,W4
00222: MOV W4,2C8
.................... ODCB = 0x0060;
00224: MOV #60,W4
00226: MOV W4,2CE
.................... PORTB ^= 0x0200;
00228: BTG.B 2CB.1
.................... for (itmp = 0;itmp < 10000;itmp++);
0022A: CLR 802
0022C: MOV 802,W4
0022E: MOV #2710,W3
00230: CP W3,W4
00232: BRA LE,23A
00234: INC 0802
00236: GOTO 22C
0023A: GOTO 218
0023E: PWRSAV #0
PostPosted: Fri Jan 25, 2013 7:50 pm
It's compiler specific but ports should probably be declared volatile :lol:
Mind, for 250 I'd expect the compiler to write the flippin code for me. Even MS visual studio is free these days
PostPosted: Fri Jan 25, 2013 8:06 pm
The microchip compiler is free if you don't want the optimiser. With the optimiser it's free for 60 days then it's $900 Hence I use the CCS one.
PostPosted: Fri Jan 25, 2013 8:33 pm
:shock: Its-how-much :shock:
PostPosted: Fri Jan 25, 2013 8:45 pm
At least they offer you a choice, pay it and get nice efficient code, or spend the money on faster chips with more memory (the microsoft way :lol: ).
Back in the day, my cheap nasty compiler for the 68hc11 was £1500. (and it WAS nasty) Thankfully the customer paid for it.
PostPosted: Sat Jan 26, 2013 8:05 pm
nice work, btw what happenet with that project from some guy on mr2oc a long time ago that was supose to get oem toyota ecus to be programable.. if anybody knows... he got in some problems dealing with calls in call in asembler code of stock ecu or something like that and gave up... ??
PostPosted: Mon Jan 28, 2013 6:39 pm
http://www.twobrutal.co.uk/forum/showth ... bly/page40
need to register though
also, take a look here >> https://www.assembla.com/spaces/3SGTE_E ... ifications
St205 WRC - Running sweet.
PostPosted: Mon Jan 28, 2013 7:25 pm
I offered to try and help the MR2OC guy but he just completely ignored me
Not even a sod off :(
PostPosted: Mon Jan 28, 2013 7:58 pm
How bloody rude is that ? :lol:
2004 Subaru WRX
PostPosted: Mon Jan 28, 2013 10:24 pm
I have a spare ICD 3 you can borrow, should work for the dspic...
