It is currently Mon Oct 06, 2025 6:20 pm
Post new topic Reply to topic  [ 79 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Thu Feb 14, 2013 2:49 pm
:( OH, THE HUMANITY :(
I've decided its time to stop throwing random bits of Python at the screen to see what works and write the beginnings of a protocol spec based on what I've done so far....
You in t'office with a bit of spare time tomorrow Chris?
PostPosted: Thu Feb 14, 2013 6:42 pm
Off to my favorite site tomorrow :(
Will be in on Saturday all being well, but don't expect much inteligence :lol:
PostPosted: Thu Feb 14, 2013 7:55 pm
oh ffs
After all that, I google CAN temp sensor on the offchance and find there's a whole standard :(
If you've got SAE access (I haven't) have a look at J1939 standard
http://zone.ni.com/devzone/cda/epd/p/id/6215
PostPosted: Sat Feb 16, 2013 10:12 pm
Circuit design done apart from connector (which I need to choose finally)
Struggling to find a connector rated to 20A, but I've stumbled on this which looks interesting. It may also save searching for a box. The only downside is the connector pins are only tin plate not gold so I wouldn't want to see these outside the cabin unless they're in a larger sealed box.
http://docs-europe.electrocomponents.co ... d4e8d6.pdf
Anyway, progress so far for anyone interested.
https://dl.dropbox.com/u/8316230/PDU/PDU_A.pdf
PostPosted: Sat Feb 16, 2013 10:30 pm
just dropping part numbers for future reference
RS.
664-7236
664-7226
664-7267
664-7258
PostPosted: Sun Feb 17, 2013 10:26 am
Been having a rethink. Just goes to show what happens when you let boffins loose on a design and forget about the application, we've ended up with a spec similar to the motec we were slating earlier.
the whole concept of canbus / remote switching is lots of small cheap simple modules placed next to the item they're controlling, thus minimizing. Wiring.
the other IMPORTANT consideration is making something quick and easy to diagnose and repair by the roadside with no tools or specialist knowledge.
So let's say a module goes pop that drives fuel pump, or headlights when It's dark.. easiest to carry a spare module, but then you need a laptop and adapter and knowledge. So, carry a full set of spare modules ready programmed ? Seems ott.
I think we need to look at the config for the whole system as a single item, downloadable via the canbus and stored in full in every module. Each module will access only the parts it needs based on its address. This means modules can be swapped for each other or a single spare without a laptop. The only proviso is that the address must be settable by the roadside, either a dipswitch inside or imo in the loom with links on 4 inputs (allows 16 addresses)
So. Ditch second chip and dual canbus (since they're not such a problem) go back to 8 in 8 out plus 4 in for address setting.
maybe in the future do a high reliability motorsport version with dual can and other similar redundant device / auto switchover features.
PostPosted: Sun Feb 17, 2013 1:01 pm
Hmm
I think the design you have is OK with twin processors
The way I see it the electronics is cheap compared to boxes, connectors etc and the board cost won't differ much. The more cheap io you can pack into the expensive box the better imo - hence it strikes me as a better option to go with the board design you had which is double handy for development
The config thing I had an idea about. After yesterdays elm327 discussions how about making a phone/tablet the central monitor?
I don't think it's unreasonable to expect that the sort of nerdy person who would deploy a can power distribution grid will have a smartphone :lol:
If all else fails and you really need the on the fly capability you can buy a cheap tablet and elm device for under a hundred sheets - pretty reasonable and the kids get a new toy when daddy isn't out terrorising the streets
Failing that making the network self heal is still only a software problem. For eg
Every module on the system backs up the config of the unit before it - 2 has the config for 1, 3 has it for 2 and 1 has it for 3. Say you pull unit 2 and replace with an unassigned one. Unit 3 needs to see unit 2 isn't talking any more and send out the commands to reprogram a blank unit
PostPosted: Sun Feb 17, 2013 4:20 pm
A few reasons for the decision.
1. Split processor software nightmares.
a. Thinking through how the software will work, each chip sees most of the other stuff via it's own canbus (if it works) but can't see it's other half except via I2C. If one canbus fails, we need to pass everything via I2C. The only way I can see it wotking as original concept is to pass ALL canbus traffic via I2C to other processor, in both directions. So, 2x canbus at 250Kbit trying to pass through 1xI2C at 100Kbit. Sausage up an alley but in reverse.
b. Setting config & upgrading software. 1xUSB port to PC, 2 chips. Who has control ? Or configure / upgrading via Canbus - has to be done twice, once for each chip.
2. The board is now bigger / more complex than the ECU. Adding the connector exceeeds the pin limit on my version of the CAD system and will require upgrade to the full unlimited version. At the time I bought it, I was evaluating several and it was cheaper to buy the demo & upgrade to full than to buy the full. I always intended to upgrade when needed, but I haven't needed to in 10 years and TBH I think the market is so limited it doesn't justify the money. So - cut it down or shelve it.
PostPosted: Sun Feb 17, 2013 4:53 pm
Ah, I was thinking along different lines, initially at least
Both connected to the same bus with switchover so basically 1 pdm would appear as two entities on the bus. So everything is identical between software.
Additional development could then allow the i2c bus to come into play to combine the 2 units into 1 via internal comms
The pin limit is a bit of a domestic pachyderm though :(
Is that down to laying the pdm and dash display on a single board?
PostPosted: Sun Feb 17, 2013 8:58 pm
All being done on different boards, the manufacturer is combining them for me.
PostPosted: Mon Feb 18, 2013 1:12 pm
Part numbers for smaller, cheaper version of box & connectors.
664-7220
664-7204
664-7254
664-7267
Thinking of laying out board so all the important connections are on the 30 pin connector so some applications can save a connector.
PostPosted: Tue Feb 19, 2013 12:00 am
Been exercising the old grey matter to produce a cycle accurate version
I now have real (virtual) hardware to play with so now have correct timing
@250Kb/S CAN speed
16 inputs. Each pin sent with full 16 bit accuracy
each packet takes ~500uS
16x = ~8mS as per picture (packets vary a little bit in size due to bitstuffing required in the protocol)
It's a bit tight :(
PostPosted: Tue Feb 19, 2013 11:44 am
Bit of datapath parammeterisation later
Now running a max of 8 inputs all with 12 bit resolution. Each PDM now takes ~1.8mS to transmit a complete input compliment
I've cut it down so each PDM has a 5mS window allotted and defined a max of 7 PDMs (+ an additional central control unit) on the network. Image shows 7 pdms all talking. Bus utilization is ~35-40%
In this configuration response time is 40mS max - almost quick enough to ditch change notification and just rely on periodic status updates
PostPosted: Wed Feb 20, 2013 2:49 pm
Random thought of the day
And if the boards aren't done and dusted......
If using a single dsPIC you have a free SPI port. SPI powered SDCARD reader modules are cheap enough....
How about storing the configuration on a SDCARD? That way if a PDM fails on the road you can swap it for a blank one simply by swapping SDCARDS
This has a couple of benefits -
Reduces NV memory requirement
You can configure the system offline then just plug the cards into modules
It gives you somewhere to log stuff like faults
Frees up 4 more inputs to the outside world
Downsides
You need a card reader + slot in the case somewhere
PIC code needs to be able to support SD - a brief search suggests that RAW format isn't difficult
Not sure of the size limit but I'd estimate a complete system configuration to be >1KB :-
@8 pdm with 8 inputs you have 64 input pins in the system
each output needs a "turn on" and a "turn off" flag for every input pin - 128 bits
each output needs some config data - flash, flash rate, current limit. Say 32 bits
There's 64 output pins in a 8PDM 8 output setup so total is 64*160 bits or ~1300bytes
Allow for a few missed things and I reckon 1.5kB of NV memory should be close
PostPosted: Wed Feb 20, 2013 3:00 pm
On a related note
Anyone got an ASIC going spare?? :lol:
