Pedals http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=7810 |
Author: | coldel [ Thu Jan 18, 2018 6:01 pm ] |
Post subject: | Pedals |
On an ST205, anyone attempted to change the pedals over to something a bit more sporty. The 23 year old rubber ones do make the interior look a bit run down! Are people using covers or replacing them altogether? |
Author: | bricktop [ Fri Jan 19, 2018 12:18 pm ] |
Post subject: | Re: Pedals |
From what I have seen Toyota GT86 ones look like a direct replacement. They are the same as ones used on sporty MR2's and IS200's. I am sure if you could find the part numbers you could get them brand new. |
Author: | coldel [ Fri Jan 19, 2018 2:35 pm ] |
I was hoping to replace just the pedals rather than the whole arm etc. is that what you mean? I might actually go out now and just check see if I can get em off! |
Author: | coldel [ Fri Jan 19, 2018 4:13 pm ] |
Well the rubber does come off on clutch and brake but gas is attached. So possible they might swap over... |
Author: | bricktop [ Sat Jan 20, 2018 3:27 pm ] |
Accelerator should come off as well. Might be screwed on. Both MR2 and IS200 should use similar assembly. GT86 looks similar as well. |
Author: | audiodjmp77 [ Sat Jan 20, 2018 8:08 pm ] |
Sorry for the hijack, but would these fit a 185 too? Sent from my Nexus 9 using Tapatalk |
Author: | coldel [ Tue Jan 23, 2018 10:28 am ] |
Have just ordered some new rubber ones for now (fiver off ebay) will look better than the 20 year old ones on there currently! Probably need to investigate a bit more what options there are in terms of drilling and fitting aftermarket ones. |
