Short Shifter ST205 http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=7799 |
Author: | coldel [ Mon Oct 23, 2017 9:39 am ] |
Post subject: | Short Shifter ST205 |
Any idea on where to get one? |
Author: | cms-gt4 [ Mon Oct 23, 2017 1:14 pm ] |
Post subject: | Re: Short Shifter ST205 |
The 16x- 7th gen all use the same style shift rod. I'm using a short shift rod from a ae92 in my 185. I just bought some thick bushings the size I needed to raise the shift assembly for clearance. I also picked up an oem 7th gen shifter which has similar dimensions to the short shifter made for the car for much less than the short shift kits. |
Author: | coldel [ Mon Oct 23, 2017 5:02 pm ] |
Thanks, a seller on ebay is saying this will fit? http://www.ebay.co.uk/itm/Quick-shift-s ... 1944067146 |
Author: | cms-gt4 [ Mon Oct 23, 2017 8:13 pm ] |
It may. The ball in the center and cups should be the same size. I do not know how much longer thevlower rod of a 7th gen shifter is. That may affect inner clearance. That is why I suggest an oem one. Keep in mine you may need to bend or cut and weld the upper section depending on angle. The 5th gen tilts back so I have to modify the 7th gen one on top for a more optimal angle. |
Author: | coldel [ Tue Oct 24, 2017 11:25 am ] |
OK thanks. Any other sources of getting one? I have seen some sites in the US but its going to come out around £250 all in to get it here. |
Author: | cms-gt4 [ Tue Oct 24, 2017 5:14 pm ] |
Do you have local junk yards? That is likely your best bet. There or ebay. If you look for a oem 5speed one from a 7th gen I imagine they are pretty cheap. |
