Rebuild SSS (Super Strat Suspension) http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=7688 |
Page 1 of 6 |
Author: | бешаный 202 [ Fri Dec 16, 2016 9:48 am ] |
Post subject: | Rebuild SSS (Super Strat Suspension) |
I brought to you how I solved the problem with a thud on the suspension arms SSS. I really like to use it SSS suspension arms, because I had the opportunity to compare with McPherson suspension, because like last machine was ST-202. But after the purchase, I discovered a terrible knock on all the front suspension, which has been difficult to locate. I started to deal with this problem. ![]() |
Author: | бешаный 202 [ Fri Dec 16, 2016 10:35 am ] |
Post subject: | Re: Rebuild SSS (Super Strat Suspension) |
The photo shows the condition of joints and bushings fingers under which they operate. https://drive.google.com/drive/folders/ ... zloQURlVTg |
Author: | бешаный 202 [ Fri Dec 16, 2016 10:53 am ] |
More photos bushings who worked in arms: https://drive.google.com/drive/folders/ ... 3prdGt6NzQ |
Author: | бешаный 202 [ Fri Dec 16, 2016 11:08 am ] |
We handle fingers leverage hinges. Grinding, but not too much because there is a certain depth of hardening. Finger in soft and hard top. https://drive.google.com/drive/folders/ ... zZsRFFRT1k |
Author: | бешаный 202 [ Fri Dec 16, 2016 12:22 pm ] |
Links work? |
Author: | dt4 [ Fri Dec 16, 2016 7:52 pm ] |
Looks like good work, have you re assembled them? What was the result? |
Author: | бешаный 202 [ Sat Dec 17, 2016 6:39 am ] |
Yes of course I brought back and 3 years they go. ![]() Here are a few photos that would understand the process of revival of suspension arms: In the photo on the link seen all kinds of plugs, which are used within the arms. This new hub made using the machine with numerical control software. https://drive.google.com/drive/folders/ ... lRkTnlQVm8 |
Author: | бешаный 202 [ Sat Dec 17, 2016 6:44 am ] |
More photos: https://drive.google.com/drive/folders/ ... 21OazB0VjQ |
Author: | бешаный 202 [ Sat Dec 17, 2016 6:50 am ] |
General view of the SSS control arms before the assembly (couples details in the photo is not enough, but you can understand the scale). https://drive.google.com/drive/folders/ ... lVlM1NVcVk |
Author: | бешаный 202 [ Sat Dec 17, 2016 7:33 am ] |
Photos ready suspension arms SSS: Myself I levers did three years ago. In the photo one of many of my works. https://drive.google.com/drive/folders/ ... HMwM2hpMnM |
Author: | бешаный 202 [ Sat Dec 17, 2016 7:41 am ] |
Here's another example embodiment. There are replacement of bushings in the suspension arm banana (yellow polyurethane). https://drive.google.com/drive/folders/ ... 2ZYUm9YZm8 |
Author: | Sirius [ Sat Dec 17, 2016 5:57 pm ] |
This looks very interesting. ![]() |
Author: | бешаный 202 [ Sat Dec 17, 2016 6:52 pm ] |
Sirius wrote: This looks very interesting. ![]() Oh sure. Most importantly, no longer need to buy new suspension arms. Just pull out the pin, unscrew the back cover and change the sleeve and on the back of new arms... ![]() |
Author: | Kris [ Sun Dec 18, 2016 12:02 pm ] |
Great work! |
Author: | бешаный 202 [ Mon Dec 19, 2016 6:04 am ] |
Kris wrote: Great work! Thank you for your appreciation of my work. |
Page 1 of 6 | All times are UTC + 1 hour |
