Hazee track build http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=7459 |
Author: | TrackToyFour [ Wed Sep 16, 2015 11:37 pm ] |
Post subject: | Re: Hazee track build |
gt4hazee wrote: .......and fit a TRD front LSD Not sure how long the TRD front diff will last if Adrian's experience is anything to go by. To look on the bright side if you are doing circuit racing then it might not be as hard on the diff as the sprints and drag events that the Fensport Gen 7 GT4X competed in?
Author: | gt4hazee [ Thu Sep 17, 2015 8:57 am ] |
That's what I'm hoping, the circuits shouldn't be as violent as sprints. Still need to find someone to strip it down - check it over - and fit it . Spoke to Fensport twice , keep saying they'll get back to me . Presume there not interested . Will have to speak to the people who rebuilt my cusco diff , bit worried as the front LSD is a lot more complicated |
Author: | mixer72 [ Sat Sep 19, 2015 10:52 pm ] |
car is looking good mate, im looking find a 1.5way rear diff but going to stay open diff in the front. |
Author: | gt4hazee [ Mon Mar 28, 2016 11:22 pm ] |
Took the car to brands to check for leaks and problems. Found a few issues and leaks but went well ![]() https://youtu.be/awAmGIg0h4U |
Author: | TrackToyFour [ Mon Mar 28, 2016 11:30 pm ] |
Sounds good. Did you fit the TRD front diff and if so, how did the car handle? |
Author: | gt4hazee [ Mon Mar 28, 2016 11:50 pm ] |
Yep trd/kaaz front diff is in .... They managed to get a full rebuild kit (plates) from kaaz. Required some bedding in but now is great. Before I suffered major understeer. But now with new tyres, new geo, re corner weighted, height change and the diff the car finally feels like it's on rails. I don't think its all the diff, but you can definitely feel doing its job . Really hope It holds out. |
Author: | бешаный 202 [ Mon Dec 19, 2016 3:08 pm ] |
Quite a good result for the 3S-GTE. Pistons stock? |
Author: | gt4hazee [ Mon Dec 19, 2016 3:54 pm ] |
бешаный 202 wrote: Quite a good result for the 3S-GTE. Pistons stock? No not anymore. think 86.5 cp pistons, eagle rods, 264 piper cams. For 1.5 /1.6 bar its about where it should be. Full boost by 4k rpm Ive been running low boost for reliability for 40min race / 30 min qualifying Still have 50 - 100 kg easy to strip and i will get it mapped for 2 bar -- but dial it back for the race |
Author: | бешаный 202 [ Mon Dec 19, 2016 5:49 pm ] |
Well shafts are not the evil you are ![]() You can be interested in a joint clearance on the piston and cylinder exposed? 50-100 kg. What to throw out of the car going? Driver? ![]() |
