Eric Thompson wrote:
From rep at KAAZ
" 1. I have to guestimate on the pricing based on the past special orders we have done. Guessing on
the high side, the front / center combo unit will probably cost about $2500~$3200. Looking at the
schematic I have, the front unit is simple design and the center unit gets all the plates inside like
other Kaaz unit. Kaaz does own the patent to this unique design. I was told by the designer, that
this kit allows the front diff to lock up only when necessary. So the car will be two wheel drive and
when necessary it becomes AWD.
2. HP rating: Can’t guarantee anything but I would say about double the stock HP.
3. Document I have is so light and it is hard to read. Looks like front is 1.5 and center is a 2 way.
We can figure this out if Kaaz gives ok on this project.
4. If Kaaz does produce this kit, service parts will be available for several years. Most internal
components used are identical to other models (clutch plates, cams, pinion gears etc…). The only
thing that will be unique to this kit will be the casing for the front and center. Generally Kaaz do
not supply the casing as parts (only internal pieces are normally offered as parts).
5. Time frame: Normally design from scratch to actual product release will take about 5~6 months.
If they were to reproduce this kit, I am sure they will do some redesigning to make it stronger
than the old design."
To get this off the ground, Eric noted it may be 20-30 units and parts will be available afterwards *GT4OC.net
GT Four
Adovansu
