It is currently Sun May 05, 2024 4:19 am
 Post subject: spanners are out !
PostPosted: Wed Jul 31, 2013 11:26 pm
hi had time for a bit o work on engine eday , stripped of turbo and exhaust as there was a few nuts and studs missing , question is ,is it a common problem on turbo engines for exhaust nuts to slacken of or a case of bad work in the past, has an xcessive motorsport manifold seems good quality , heard a lot about cracking !! , also ive removed aircon pump ,is it ok to just disconnect wiring on pump and tape up or is there a procedure to follow , thanks in advance
 Post subject: Re: spanners are out !
PostPosted: Wed Jul 31, 2013 11:37 pm
OK to just unplug aircon pump, no errors caused just aircon won't work.
On the 185, the 7 stud manifold normally warps and this is normally associated with an exhaust leak and pulled threads in head - may be people overtightening to try to cure leak or could be manifold warp was enough. Either way, helicoils are IMO the best answer. You can get 'repair studs' with a larger thread one side, these are a pain to get out in the future when the nut has stuck itself to the stud, which then can't come out through the manifold.
In your case, if you have an XS power manifold, these have a habit of not being flat from the factory so a skim may be in order (or get a standard one)
Turbo nuts do sometimes come loose, usual solution if they keep coming undone is to buy new ones from Toyota - not cheap but they are very special and don't come loose.
PostPosted: Thu Aug 01, 2013 7:58 am
cheers lad only the end stud didnt feel right x fingers will keep you updated,
PostPosted: Sat Aug 03, 2013 8:34 am
got her put back together , engine is very good but not impressed with power , have decided to go down the v8 route as it needs a clutch and alternator and dont want to spend money on motor and find out im not happy with it , ive a 4.6 rover engine slightly tuned which im gonna drop in , will keep ya updated with pics , ive set myself 12 mths to do it so wish me luck , will be parting out engine and box if anyones interested
PostPosted: Sun Aug 04, 2013 12:17 am
I presume you're going rwd ?
Should be fun with normally asthmatic responsiveness.
PostPosted: Sun Aug 04, 2013 12:35 am
yeah man motors putting out 300 bhp and 350 torques, should be a good combination , love the celica shape , had a late seventies st about twenty years ago loved that too !! ps is the rear diff lsd and are they a strong unit
PostPosted: Sun Aug 04, 2013 9:32 am
There are plenty of high power gr4s running standard drivetrain so it should take it ok. May be worth keeping an eye on temperatures though as they normally only take half the power.
standard are LSD but not certain about all 185s. If needed a 205 diff is a straight swap.
PostPosted: Sun Aug 04, 2013 10:07 am
cheers lad will keep ya updated
