oil catch cans http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=6636 |
Author: | yellowchinaman [ Thu Jul 18, 2013 2:49 pm ] |
Post subject: | oil catch cans |
I've always thought of the universals being a bit of an overkill. Then I came across this: http://oilcatchtank.com/ What do you think? Can this work? Also what size should I get for our 3SGTE? |
Author: | MrDB [ Thu Jul 18, 2013 3:35 pm ] |
Post subject: | Re: oil catch cans |
They look just like. http://www.machinemart.co.uk/shop/produ ... -auto-drai |
Author: | yellowchinaman [ Thu Jul 18, 2013 3:53 pm ] |
Tru. But how does air filters operate differntly from catch cans? Air filters have an element filteration inside. Think I can simply remove it and use it as a catch can? Also many universal cans only have fittings of 10mm/15mm/19mm but our on the 2SGTE is 22mm for the ID of the hose. How have people gotten round this? Extreme reducers? |
Author: | darrylp [ Thu Jul 18, 2013 6:47 pm ] |
MrDB wrote: That's an airline filter for removing mainly water.... The intake is probably 1/4 bsp way too small for a crankcase vent in volume of flow -- Darryl |
Author: | Sirius [ Thu Jul 18, 2013 8:31 pm ] |
The standard catch tank works fine IMO. |
Author: | yellowchinaman [ Thu Jul 18, 2013 9:01 pm ] |
not doubting that the stock one is fine but today I discovered that my can had cracked and the L hose had split which was the cause of my oil leak so looking to buy a replacement. Also the mini breather I have on the end which usually feeds back to the intake was soaked I oil. |
Author: | TrackToyFour [ Thu Jul 18, 2013 10:48 pm ] |
Sounds like your engine is exhibiting symptoms of excessive crankcase pressurisation if the filter is soaked in oil. Tired, high mileage engine? |
Author: | yellowchinaman [ Fri Jul 19, 2013 9:58 am ] |
yep. About quarter of a million miles. Whats the remedy to this? |
Author: | darrylp [ Fri Jul 19, 2013 10:51 am ] |
yellowchinaman wrote: yep. About quarter of a million miles. Whats the remedy to this? A engine overhaul ? Ie. Rebore, or just new rings with a hone ? Head off and regrind valve seats, new valve seals. -- Darryl |
