It is currently Mon Jun 03, 2024 2:44 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Fri May 31, 2013 9:01 am
Disabling the tvsv doesn't make the waste gate open all the time. The waste gate is a mechanical system. Perhaps when I'm next passing your way likely to be next weekend I could stop in and have a look.
In the meantime check all the plumbing. Is the right way round and confirm by disabling the controller that the boost holds steady just on the actuator pressure.
PostPosted: Fri May 31, 2013 9:54 am
Thanks. Ill check all the pipung however it was all worjin before i snipped the ecu wire so i mite of done sommet wrong there... what r u supposed to do with the wire after u cut it? Does it need to be connected to anything else? I did it late last night so wasnt much light so taped it off just to see if it made a diff havent used car this morning yet
PostPosted: Fri May 31, 2013 7:33 pm
I hate to say this but if you were starring in The Hurt Locker we would be scraping your remains off the ceiling! Snipping ECU wires scares the crap out of me so I do the simple way of blocking the actuator hose. Too late I know :-( If it were me I'd try and reconnect the ECU wire you have snipped then at least you can try and return the actuator to standard as Mike has suggested. As he says, your problem is likely to be a mistake with the plumbing so should be an easy fix. It helps if you can get someone to help who has done this on their own car.
If it makes you feel any better I discovered a while back that my boost controller plumbing had not been reconnected properly after a well known turbo specialist had done some work. Said specialist works on WRC cars but human error can still be a factor.
PostPosted: Sat Jun 01, 2013 7:45 pm
Hi did wot u sed reconnect vsv wire... boost holds steady on 3rd and 4th with standard actuator... set boost controller piping back up and it is back to how it was... heres a video of it and how looses pressure higher in rpm maybe thats just what ill have to put up cos looking where the vsv is bolted on ill never get to it myself... https://www.youtube.com/watch?v=4ayHmrq ... ata_player
