It is currently Fri May 03, 2024 6:22 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
 Post subject: Re: LPG
PostPosted: Tue Jun 11, 2013 11:02 pm
Re-shimmed the valves again the other day while the cam belt was off changing the water pump. 2 exhaust valves down to 0.1mm clearance (spec .28-.38) 2 more down to .15, a couple at .25 rest were in spec. Funnilly enough, the most worn valves were on cylinder 2 and 3. 1 & 4 were fine. Inlet valves don't seem to suffer regression. I didn't keep records of milage last time but I suspect probably about 30K miles since last re-shim.
Hopefully I'll have another engine going in within a couple of weeks as this one is still suffering mild overheating even with the water pump now done. Suspect warped head / gasket or hairline crack in block - almost certainly a direct result of water loss from pump. I'll keep records of mileages and initial valve clearances on this one to give a better idea of wear rate.
PostPosted: Thu Jun 13, 2013 6:56 pm
Cheers Nibbles. Any form of data logging will be of great use
Users browsing this forum: No registered users and 24 guests
