It is currently Mon Apr 29, 2024 1:50 pm
 Post subject: Aircon removal
PostPosted: Tue May 07, 2013 3:59 pm
Good afternoon folks.
Some nice weather today, which must be because I've removed my aircon compressor pump!
As part of my planned maintenance I began removing the aircon system from the car. So far I have removed the pump and fitted a shorter fan belt and grooved tensioner pulley, and cut back the pipework below. I plan to gradually remove the rest of the pipework and the chiller unit/condenser etc over my limited free time.
My question is this... Is there any sensors/electrical connections/fuses I sould remove at this stage to completely isolate the system?
I've had a look on the guide for the 165's on GTFOURS.CO.UK, and it mentions issues with the radiator fan running continuously.
Cheers again!
 Post subject: Re: Aircon removal
PostPosted: Wed May 08, 2013 6:11 pm
On the ST185 you need to keep the sensor from the A/C line up near the diagnostic port. Don't know on the 205 if its needed.
Darryl
Darryl
PostPosted: Thu May 09, 2013 10:20 pm
I'll check it out, cheers.
Users browsing this forum: No registered users and 190 guests
