http://gt4dc.co.uk/forum/
what level of mods could i do too....
http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=6484
Author:  mahender [ Mon Apr 22, 2013 9:46 am ]
Post subject:  what level of mods could i do too....
I wanted to ask what I could do that can still be managed by the cars ecu and won't over stress any other bits excessively
I am aware if I uprate head then I have so much freeplay in increasing the boost. As you are aware I'm not a mega mechanic.
If I were to run a fmic would it be bolt on per se and I could reset the ecu and continue driving.
What about a decat or straight down pipe can these just be bolted on.
What about both would I then have to set the four up to accommodate these?
I have an eye on a few bits that I want. Namely a bolt on fmic which requires no cutting and no battery relocation.
Thanks...
Author:  two_OH_five [ Mon Apr 22, 2013 10:27 am ]
Post subject:  Re: what level of mods could i do too....
You'll be fine with a stock ecu and that level of mods provided the basic engine is running well at the moment
Author:  Muddy Water [ Mon Apr 22, 2013 1:44 pm ]
Off the top of my head, I would start with:
Air Intake (panel filter or Induction system)
Exhaust and decat (only caveat is that you may get boost creep fitting a decat pipe)
Decent Boost controller
Decent dump valve (Bailey DVxx?)
FMIC
All pretty much bolt on/wire up.
Boost controller would need setting correctly.
Then look at the following:
ST205 head conversion (port and polish) - talk to TGT about this (they've been there and done it).
(Optional oversize valves, uprated Camshafts,...)
Pretty much depends on your budget.
