It is currently Mon May 13, 2024 2:06 pm
 Post subject: 4evacelica work
PostPosted: Sun Apr 07, 2013 6:37 pm
As promised and long overdue I am going to do a little thread on repairs done now and in the future
Steel driveshaft guard bent well out of shape
Engine out
Cracked exedy clutch friction plate
Rear and front crank seal starting to leak
Power steering pump main pivot bolt missing
Martin
We now have a new website
 Post subject: Re: 4evacelica work
PostPosted: Sun Apr 07, 2013 7:28 pm
Whats your opinion on Exedy clutches?
PostPosted: Sun Apr 07, 2013 7:32 pm
I am forming an opinion based on the picture!
PostPosted: Sun Apr 07, 2013 7:42 pm
Ive never had any issues with exedy clutches apart from there a bit smelly if slipped but theres more to this scenario as when it has been fitted by whoever the master cylinder hasnt been adjusted to compensate for the new clutch so the clutch has been dragging badly which won`t of helped the situation it was apparently very bad to engage and change gears so maybe that has contributed to the failure
Martin
PostPosted: Sun Apr 07, 2013 7:56 pm
Engine base timing out by 1 tooth on each of the cam pulleys
Damage to lower timing belt cover
Cause of the damage the guide plate for the timing belt is bent so has been cutting through the cover
Martin
PostPosted: Thu Jun 13, 2013 9:36 pm
Magnecore plug lead failed
Leaking block core plug
Next pics show the internal condition of the engine as it all comes apart, etc head gasket had blown on this particular engine
Martin
PostPosted: Thu Jun 13, 2013 10:29 pm
Sanding block for checking/cleaning mating faces
And so begins the big clean up, block was thoroughly cleaned first then mating faces, etc
New core plug fitted
Full toyota engine gasket set was a cheaper option due to need so many seals and gaskets
Martin
PostPosted: Fri Jun 28, 2013 12:15 am
Refurbed head
New cam seals installed
Martin
