MSD Blaster SS Coil
http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=6452
Author:  jgtcracer [ Fri Apr 05, 2013 6:26 pm ]
Post subject:  MSD Blaster SS Coil
A mate of mine has offered me msd coil for the car for free and said on his volvo t5r it improved fuel economy and ran smoother. Anyone got any opinions and to be honest, will I even be able to fit it to an st205??
http://www.msdpower.co.uk/product_info. ... 98e02b37b5
cheers guys
Marcus
Author:  Kris [ Fri Apr 05, 2013 8:29 pm ]
Post subject:  Re: MSD Blaster SS Coil
Not required... unless you have excess money to burn :D
Author:  jgtcracer [ Fri Apr 05, 2013 8:56 pm ]
it is free so dont see any drawbacks to be honest
Author:  Nibbles [ Fri Apr 05, 2013 9:58 pm ]
The main potential drawback is whether it is compatible with the standard igniter and ecu setup. There are a number of things you will need to know - Will it work CORRECTLY, WITHIN SPEC. with the dwell time used by the standard ECU ? Will it draw excessive current from the igniter thus overloading it ? Will it generate excessive voltage on the primary at spark and overload the igniter ? (40KV and 70:1 means nearly 600V, seems very high to me).
I would also want to know how the output compares to standard as you may find no benefit whatsoever.
It's quite likely it would appear to work if you wire it in, but failure may be just around the corner for any of the reasons above - including engine failure as a result of over-advanced ignition.
Author:  jgtcracer [ Fri Apr 05, 2013 10:11 pm ]
chris, youve just scared the beejesus out of me so it aint happening!!
