It is currently Tue Oct 07, 2025 2:47 am
Post new topic Reply to topic  [ 142 posts ]  Go to page 1, 2, 3, 4, 5 ... 10  Next
 Post subject: 2009
PostPosted: Thu Apr 04, 2013 12:08 am
Imagepictures tell a thousand words and all that.
The curren was a daily at the time. The silver st205 is what this thread is about. Image
PostPosted: Thu Apr 04, 2013 12:20 am
3S-GTE on throttlebodies?
PostPosted: Thu Apr 04, 2013 6:22 am
Looks like a really interesting project - please post more! :D
PostPosted: Thu Apr 04, 2013 11:10 am
a turbo + ITS's, looks interesting to me, give us more input about the ITB construction :lol:
PostPosted: Thu Apr 04, 2013 1:31 pm
4th pic. Centre console/fuse board.
5th pic. Blitz/kkk turbo overhauled (made 295ftlbs/316bhp)@1.6 bar
6th pic. Blacktop 45mm itbs with a custom adapter designed by Dan off here. The trumpets are too big to fit inside a pulsar plenum so will have some shorter ones made. Phenolc gasket. Bosch idle control valve underneath with a vac canister for fuel pressure, boost and map takeoffs. The head is ported and polished and port matched with overhauled with standard valves, new oem springs and seals. Ge na cams on the inlet and exhaust (252degree/9.8mm lift). Cam cover is off a rev 3 3sge modified to suit zzfe cop, baffles removed and bunged breathers (more on that when I show u the block). Custom dual feed fuel rail with 600cc ev14 top feed injectors.
Pic4. Ported standard oil pump cover.
PostPosted: Thu Apr 04, 2013 11:41 pm
The Cage. CDS2 and complies with current MSA regs
My mate seam welding
To do list
OOOPS
5S block polished and deburred. Crank Caps have also had the same treatment as they are known to crack. Polished and balanced and mildly knife edged 3S 86mm crankshaft.
Turbo Compressor housings
PostPosted: Fri Apr 05, 2013 12:15 am
Amazing attention to detail compared to my build so I hate to think of what the time/effort/cost must be. What's the current status of the project?
PostPosted: Fri Apr 05, 2013 7:26 am
Thank you but But i cant dismiss that your project has been an eye opener as to what can be done and done well. Also a massive influence on me to keep my car. Spent just under 10k on this car including buying the car (1k) and got about 4-5k to go.
At the minute the pistons are on order. Should receive them in 3 weeks. The engine should be done in 2 months as I'm still yet to order custom rods, make plenum backplate and trumpets etc.
The body needs harness bolts welding in and seat rails. Then it's ready to be prepped for paint. Should be painted by Xmas depending on how quickly I can save. Goin holiday this year so gotta save for that lol
PostPosted: Fri Apr 05, 2013 2:37 pm
Love the idea of the 5S block - please keep all that info coming! :)
PostPosted: Fri Apr 05, 2013 3:52 pm
looks like you may have a competitor after all don!!!
Toyota Celica GT4 ST205
Toyota Celica GT4 ST185
PostPosted: Fri Apr 05, 2013 10:06 pm
Looks an excellent build, I'm glad you decided not to walk away from it.
This is a bit extreme for removing the underseal. :lol:
PostPosted: Sun Apr 07, 2013 4:59 pm
great built, but does i advise to place a fire extinguishers in your near :lol:
looks like you modified the oil pump a little, just a tip if you are able to get a cheap gen.4 oil pan nr.1 you can
use a 3S-GE oil pump which has the highest flow, the crank sensor on these engines is the issue why it ain't fit the
gen3 sump
a water pump upgrade is possible too if interested
love the ITBs, should i built a engine anytime again i go that way too :)
PostPosted: Sun Apr 07, 2013 11:40 pm
Thanks for the comments.
Sunny I was goin to use a trigger wheel bolted to the inner part of the crank damper. Would like to run the trigger wheel and cover from later rev 4 but they are rare as hens teeth and therefore expensive. What makes you say 3sge has best flow? Does it have thicker rotor/annulus? Was goin to modify the cover to fit 5s rotor/annulus as its about 10% thicker giving more pressure.
Still wondering whether to do this. As for flow ported the pump, cover and sump as the oil holes vary and taper (10.5mm to 12.5mm) to and from the filter. Left the block main oil gallery as it is (11mm).
Not a great pic showing the oil hole(this is the one to the filter in the sump).
Appreciate the input :) I am using Davies Craig EWP but more on that later ;) all will be revealed.... Most if it.
PostPosted: Mon Apr 08, 2013 7:35 pm
here some infos about the oil pumps (and water)
viewtopic.php?f=13&t=5300
the 3S-GE Blacktop with dual VVTI has the most flow of all 3S oil pumps, he also used the smaller pulley, thats the setup i built to my engine too
i would not modify that much on that part of the engine, it just means death if you had a damage on that pump :lol:
looks like you need to much gen.4 parts in front of the price, the gen.4 has all the points you list, cranks sensor and trigger and the correct oil pan for the pump
i found a EWP just cause a more complex setup, i found no reason to use one so i built a uprated oem one , got that trick TTE 8)
PostPosted: Mon Apr 08, 2013 11:02 pm
Thanks for the info. I wouldn't be surprised if the beams setup taper and restrict as much as the standard 205 pump. There would be no reason why i would hurt the oem pump by porting the cover and sump, if anything it would give it an easier life. Did some googling myself. Standard pump will provide enough pressure. If one comes up at the right price I will upgrade and mire than likely still modify to remove restrictions. For the time being I will stick to the stock pump as I'm only revving to 7500rpm maximum. Depends where the power rolls over. Found this on imoc.co.uk http://www.imoc.co.uk/forums/viewtopic.php?p=1480627
Main reason I am using an electric water pump is that it will run after the engine is switched off and to feed coolant from the four core plugs at the front (exhaust side) of the engine. Using a 5s block as overall its a stronger block but every little helps to keep from shocking the engine to cold-er water bursts to one side of the engine when the thermostat opens. Just trying something different. If it works all the better. If not back to what does work ;)
Anyway got pistons through today
5sfe piston on the left, 3sgte piston on the right.
Custom piston on the left, 3sgte on the right. Note compression heights.
Piston at TDC with 86mm crank.
Ordering rods tommorrow. Ordered flywheel today from TTV. Should be lighter than 4kg but will see.
Oh and thinking of selling the Blitz K3T turbo and Audi S2 wastegate (both refurbed and good to go, needs custom manifold) PM if interested. I'm after something smaller.
Thanks
