http://gt4dc.co.uk/forum/
FMIC Question
http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=6427
Author:  niblettr [ Tue Mar 26, 2013 10:02 pm ]
Post subject:  FMIC Question
Why do all FMIC setups use stainless or ally (i'm taking about the pipework)
Why not use samco hosing or cheaper equivalent?
Yes, I can see the appeal to the eye, but that's it?
I would like to have a setup done quick and am thinking, whats wrong with silicon and or rubber (not sure what material it is) piping???
cheers
Author:  Sirius [ Tue Mar 26, 2013 10:31 pm ]
Post subject:  Re: FMIC Question
Aluminium pipe is a lot cheaper than silicon, it won't bend, melt or flex like silicon.
If you did this (and I don't suggest you do) you'd still need metal connectors and clamps for the bends.
Author:  Sunny [ Tue Mar 26, 2013 10:39 pm ]
what will a rubber/silicone do under pressure and negativ pressure......... :)
use as much pipe as possible and just use a rubber to compensate motion and to do a connection
Author:  TrackToyFour [ Tue Mar 26, 2013 11:34 pm ]
I think this could be quite an amusing project to use samco hose. Please video for our entertainment! Even better than the guy who fitted a header tank without a pressure cap. Time for me to put the kettle on....... :lol:
Author:  niblettr [ Wed Mar 27, 2013 12:27 am ]
ahhhh, just got Queen song "Under Pressure" in my head.....
thanks
Author:  Animal66 [ Wed Mar 27, 2013 4:30 am ]
* Hands up lol :)
Author:  jgtcracer [ Wed Mar 27, 2013 8:41 am ]
as sunny said the whole setup may collapse under vaccum.
Author:  Nibbles [ Wed Mar 27, 2013 9:46 am ]
20psi x lots of square inches. I have a vision of a Celica floating above the traffic on a samco balloon.
seriously though, after turbo should be mostly pressure, which will hold the pipe open, especially at high flow rates. I can forsee a situation where.nailing the loud pedal after a period of overrun at high rpm will suck the pipe shut which will even prevent the turbo spooing to blow it back open.
Author:  niblettr [ Wed Mar 27, 2013 10:46 am ]
Really want to go down FMIC route but dont want to spend loads....
what do I do???
Ideally, I would buy the core first, save then buy pipes to suit..
Author:  Treacle [ Wed Mar 27, 2013 12:09 pm ]
Doing it in Samco will cost double what it costs in hard pipes - ask Gary, his original FMIC on his st165 was all done in Samco with joiners and I believe it cost him a pretty penny at the time.
Also every joiner is a weak point and potential boost leak location, if you did it all in silicone you would have 20+ possible boost leak locations, whereas a good hard pipe kit will only have 4 - turbo joiner, throttle body joiner and 2 intercooler joiners.
Also silicone joins disrupt flow a lot more than a smooth metal pipe.
So basically I can't see any reason why you would want to do it, I don't think there are any plus points!
Author:  jgtcracer [ Wed Mar 27, 2013 12:14 pm ]
looks like you need to be patient mate and save to do it properly
Author:  Treacle [ Wed Mar 27, 2013 12:15 pm ]
If you want a cheap kit I have a spare Evo 6 core and a brand new set of the eBay st205 pipe kits, plus a load of extra pipes and joiners at my folks place near Sturninster Newton - you can have it all in the cheap as I don't need it and its just getting in the way.
Author:  dale [ Wed Mar 27, 2013 2:50 pm ]
as all above mate, if going fmic do it right or you might be less efficient than the cc.
Author:  Gary ST165 [ Wed Mar 27, 2013 2:52 pm ]
we used "some" silicon..
^^ no issues at 1.2 bar
