Good pictures of straight air intakes http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=6403 |
Author: | jgtcracer [ Mon Mar 18, 2013 8:18 pm ] |
Post subject: | Good pictures of straight air intakes |
looking for lots of good pictures of straight air intakes for the st205 so that I know exactly what Im making. Cheers guys |
Author: | Nibbles [ Mon Mar 18, 2013 8:42 pm ] |
Post subject: | Re: Good pictures of straight air intakes |
Is this straight enough for you ? http://www.autosiliconehoses.com/alloy- ... -size.html - 75mm for standard/hybrid turbo and apexi filter. ![]() |
Author: | Insanity-74 [ Mon Mar 18, 2013 9:43 pm ] |
Author: | Sunny [ Mon Mar 18, 2013 10:54 pm ] |
Hi, if you have enough time keep on waiting, i started a carbon airbox built with a company in CZ last week, so possible in late summer of fall we have a box for our cars, but i must say that this very depends on the price and construction so currently it is just the beginning so no specific datas yet greetz |
Author: | TrackToyFour [ Tue Mar 19, 2013 12:37 am ] |
What are you trying to achieve with a straight air intake? The OEM flat panel filter in the stock airbox is very efficient and sucks in cool air from the resonator in the inner wing well away from hot air in the engine bay. It might not look sexy but it does a very good job. The clone of the TTE airbox/plenum which Sunny is working on would be worth considering if you are looking to upgrade the stock system. |
Author: | jgtcracer [ Tue Mar 19, 2013 8:22 am ] |
Ive not got a stock intake anymore and as my oem induction hose has started to perish I thought I could make a straight air intake and run a cold air feed to it by removing the headlight whilst on track. There are 2 hoses coming off my intake currently, one is for the crankcase breather, whats the other that connects to a hardpipe behind the block? There is also what looks like a intake temps sensor thats just rattling around inside the engine bay. I havent had any problems running so what effect is it having? cheers guys |
Author: | Nibbles [ Tue Mar 19, 2013 9:27 am ] |
The second pipe is to the idle up valve. Either make a hole for it or fit a small filter to it. the sensor is the intake temp. Ideally make a hole for it in the pipe, faili that stick it in the cold air box next to the filter. |
Author: | jgtcracer [ Tue Mar 19, 2013 9:39 am ] |
So I can get away without welding any holes on the intake pipe if I place a mini filter on the idle up valve and fit my catch can (vented to atmos) to the crankcase breather! thats brilliant, thought I was going to find it a little more complicated as I dont have access to a welder. cheers chris marcus |
Author: | Nibbles [ Tue Mar 19, 2013 7:16 pm ] |
It would be advantageous to put the inlet temp sensor in there, but that just needs a hole and gromet the right size. My 185 doesn't have inlet air temp so I just have a straight piece of pipe (hence my first post) |
Author: | Sunny [ Tue Mar 19, 2013 10:58 pm ] |
Hi, if it is just about the intake hose, i have one for you, if you are interested i can have a look for cracks/damages and sent you some pictures if it is still fine..... greetz |
Author: | myitshot [ Wed Mar 20, 2013 3:12 am ] |
TrackToyFour wrote: What are you trying to achieve with a straight air intake? The OEM flat panel filter in the stock airbox is very efficient and sucks in cool air from the resonator in the inner wing well away from hot air in the engine bay. It might not look sexy but it does a very good job. The clone of the TTE airbox/plenum which Sunny is working on would be worth considering if you are looking to upgrade the stock system. just wanted to input but if you were interested in a copy of the TTE airbox then the gt4oc has them forsale ![]() |
