It is currently Mon Oct 06, 2025 3:50 am
 Post subject: FMIC Question
PostPosted: Tue Mar 26, 2013 10:02 pm
Why do all FMIC setups use stainless or ally (i'm taking about the pipework)
Why not use samco hosing or cheaper equivalent?
Yes, I can see the appeal to the eye, but that's it?
I would like to have a setup done quick and am thinking, whats wrong with silicon and or rubber (not sure what material it is) piping???
cheers
St205 WRC - Running sweet.
 Post subject: Re: FMIC Question
PostPosted: Tue Mar 26, 2013 10:31 pm
Aluminium pipe is a lot cheaper than silicon, it won't bend, melt or flex like silicon.
If you did this (and I don't suggest you do) you'd still need metal connectors and clamps for the bends.
PostPosted: Tue Mar 26, 2013 10:39 pm
what will a rubber/silicone do under pressure and negativ pressure......... :)
use as much pipe as possible and just use a rubber to compensate motion and to do a connection
PostPosted: Tue Mar 26, 2013 11:34 pm
I think this could be quite an amusing project to use samco hose. Please video for our entertainment! Even better than the guy who fitted a header tank without a pressure cap. Time for me to put the kettle on....... :lol:
PostPosted: Wed Mar 27, 2013 12:27 am
ahhhh, just got Queen song "Under Pressure" in my head.....
thanks
PostPosted: Wed Mar 27, 2013 4:30 am
* Hands up lol :)
PostPosted: Wed Mar 27, 2013 8:41 am
as sunny said the whole setup may collapse under vaccum.
Toyota Celica GT4 ST205
Toyota Celica GT4 ST185
PostPosted: Wed Mar 27, 2013 9:46 am
20psi x lots of square inches. I have a vision of a Celica floating above the traffic on a samco balloon.
seriously though, after turbo should be mostly pressure, which will hold the pipe open, especially at high flow rates. I can forsee a situation where.nailing the loud pedal after a period of overrun at high rpm will suck the pipe shut which will even prevent the turbo spooing to blow it back open.
PostPosted: Wed Mar 27, 2013 10:46 am
Really want to go down FMIC route but dont want to spend loads....
what do I do???
Ideally, I would buy the core first, save then buy pipes to suit..
PostPosted: Wed Mar 27, 2013 12:09 pm
Doing it in Samco will cost double what it costs in hard pipes - ask Gary, his original FMIC on his st165 was all done in Samco with joiners and I believe it cost him a pretty penny at the time.
Also every joiner is a weak point and potential boost leak location, if you did it all in silicone you would have 20+ possible boost leak locations, whereas a good hard pipe kit will only have 4 - turbo joiner, throttle body joiner and 2 intercooler joiners.
Also silicone joins disrupt flow a lot more than a smooth metal pipe.
So basically I can't see any reason why you would want to do it, I don't think there are any plus points!
PostPosted: Wed Mar 27, 2013 12:14 pm
looks like you need to be patient mate and save to do it properly
PostPosted: Wed Mar 27, 2013 12:15 pm
If you want a cheap kit I have a spare Evo 6 core and a brand new set of the eBay st205 pipe kits, plus a load of extra pipes and joiners at my folks place near Sturninster Newton - you can have it all in the cheap as I don't need it and its just getting in the way.
PostPosted: Wed Mar 27, 2013 2:50 pm
as all above mate, if going fmic do it right or you might be less efficient than the cc.
PostPosted: Wed Mar 27, 2013 2:52 pm
Car Model: ST165
we used "some" silicon..
^^ no issues at 1.2 bar
ST165 turbo 4WD
