It is currently Mon Oct 06, 2025 2:32 pm
 Post subject: Stigs 185 forged rebuild
PostPosted: Sat Feb 16, 2013 1:12 am
Another forged rebuild for you to see, this one was rebuild previously by someone and failed soon after, pics will show why
Engines out
Flywheel covers top and bottom missing
Power steering idle up valve damaged
Knock sensor wiring
Knackered water elbow sensor and rotor arm
Martin
We now have a new website
PostPosted: Sat Feb 16, 2013 1:50 am
Inlet cam timing out by 1 tooth
Crank pulley was seriously tight lol
Damaged oil pump
Martin
PostPosted: Sat Feb 16, 2013 2:01 am
Contamination in the sump and on the pick up pipe
Now to reveal the shining problem with this engine, bear in mind it didnt do many miles after rebuild before failing
No.4 big end bearing problem I reckon
No.4 big end bearings have spun and welded themselves together
Pretty much all the bottom end is fubarred pics of some of the bearings
Martin
PostPosted: Sat Feb 16, 2013 2:26 am
I wonder which came first, the contaminated oil chicken or the knackered bearing egg
Looks pretty sad all round though. On the bright side if it didn't spin a main bearing the block should go again although the quality job suggests it will need a thorough measuring
PostPosted: Sat Feb 16, 2013 8:38 am
were the other parts of the rotor arm inside the cap?
Toyota Celica GT4 ST205
Toyota Celica GT4 ST185
PostPosted: Sat Feb 16, 2013 12:40 pm
That pulley holding tool made me giggle.
Out of interest, was it an amateur build or a garage ?
PostPosted: Sat Feb 16, 2013 9:15 pm
No thats how it looked when cap removed
I have no idea I never ask who previously built engines I do, only interest I have is sorting it out
Martin
PostPosted: Sat Feb 16, 2013 11:50 pm
worrying to think that someone would screw the distributor cap on knowing the rotor arm looked like that :shock:
that cant possibly of been a garage could it??
sounds abit like my mates garage actually!! :D
PostPosted: Sun Feb 17, 2013 1:06 am
:lol: You would be surprised what comes out of some garages :lol:
PostPosted: Sun Feb 17, 2013 10:41 am
I'm only surprised when a garage does a good job. I used to have the job of putting my sisters car right after it had been to a garage, now I do the lot.
After a clutch change in the lake district, she was having trouble getting gears so she drove it down the country to me. While coming down the motorway the front of the bonnet started flapping. Turns out they had tack welded the bonnet on and a weld had broken. The gearchange problem was down to them forgetting that part of an engine mount went on the gearbox bolts, so they just bent it out of the way rather than remove the 2 bolts.
PostPosted: Thu Feb 21, 2013 12:49 am
Ye I can imagine its an unfortunate fact
Martin
Users browsing this forum: Google Adsense [Bot] and 9 guests
