It is currently Sat May 04, 2024 11:59 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Feb 23, 2013 12:37 am
Oil pump pick up and sump baffle plate installed
Aluminum sump section sealed up ready for install
Cut outs to allow clearance for the arp mains studs install
Aluminum sump section installed
Steel sump section installed
Martin
We now have a new website
PostPosted: Sat Feb 23, 2013 12:45 am
View from the top with everything installed
Coming together nicely
Arp head studs installed
1.6mm cometic head gasket installed
Martin
PostPosted: Sat Mar 30, 2013 8:43 pm
Cars all back up and running but as usual am well behind on the threads so for once am going to finish these build threads for once :lol:
New bypass hoses fitted
Exhaust manifold stud threads stripped in the head
Threads repaired, pictures not brilliant but gives you the idea
Martin
PostPosted: Mon Apr 01, 2013 11:30 am
Great pictures and info Martin, good man!
PostPosted: Sat Apr 06, 2013 10:12 pm
Coming together nicely :)
New hose from hell fitted
New timing belt kit ready to be fitted
Good example of the attention to detail I give my engine builds, daz`s engine had the wrong oil pump pulley fitted which will make a difference, the smaller pulley is st205, the larger one is st185
Martin
PostPosted: Sat Apr 06, 2013 11:21 pm
Interesting collection of parts on this engine Martin. I spy an ST205WRC exhaust manifold, UK water elbow, JDM cylinder head. Possibly more? I presume the wastegate take-off is via an adaptor between the OEM exhaust manifold and the turbine flange? Seems to be a common solution in the MR2 Turbo.
PostPosted: Sat Apr 06, 2013 11:25 pm
Hiya don
There is an adaptor flange between the turbo and manifold for the external wastegate on this set up
Its turned out really well has this build its hitting 1.3bar at 3300rpm so daz is loving it :-)
Martin
PostPosted: Sun Apr 07, 2013 8:42 pm
Priming the new engine before anything is cranked or turned, etc means as minimal initial start up wear as possible :D
Martin
PostPosted: Sun Apr 07, 2013 9:13 pm
Interesting, I wasn't aware there was different size oil pump pulleys?
presumeably the st185 pulley was used for the previous build as it was thought to give higher capacity?
Steve Gillies
ST-165 88 UK
www.GT4-Play.co.uk
PostPosted: Sun Apr 07, 2013 9:28 pm
The previous engine was a standard original build so work that one out
PostPosted: Mon Apr 08, 2013 12:00 am
As per my earlier observation the mixture of parts would indicate that whoever did the previous build on this engine used a parts sourced from more than one engine so the use of a 185 pulley may be random rather than by design?
PostPosted: Mon Apr 08, 2013 11:24 pm
Yip I reckon so don, the original build engine internals look genuine with the genuine toyota silicone also but it had deffo had a head gasket previously done and obviously had some other work done as per wrong parts per generation of engine fitted
Martin
PostPosted: Sun May 12, 2013 9:37 pm
Again pictures of the engine coming together nicely
Torquing up crank pulley
Coming on
Martin
PostPosted: Sun May 12, 2013 9:47 pm
Catch can broke
PCV valve broke
Bolt and plug on bits coming together
Flywheel on and torqued up
Martin
PostPosted: Thu Jun 06, 2013 11:42 pm
Next job was to try clean the gearbox up as best as I could at the time as it was plastered in grease and oil
This was what was left of the gear shift bearings that had been used to replace the rubbers
Clutch refitted
Replacement shifter bushes I have made up
Martin
Users browsing this forum: No registered users and 22 guests
