Hello :) - Blown Turbo
http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=6139
Page 1 of 3
Author:  Dave Dorson [ Sun Dec 23, 2012 10:16 pm ]
Post subject:  Hello :) - Blown Turbo
So I'm Dave. From Stamford (UK) and have just bought my first GT-Four :)
It's a 94 WRC ST205, purchased with a blown turbo and a bodged FMIC.
I'll correct the bad bits, replace the broke bits, and clean it up and use it.
Here's a shot of what we found when we took the turbo off
:lol:
Here's the car as I found it
It'd been stood a year. Jump started, but smoked a lot.
I'll need new discs and pads, and the turbo stuff sorted.
I'm also planning to fit an Evo 7/8 FMIC in place of the bar and plate one that's currently fitted (and over-sized IMO) and carry out an Air Con delete to save some weight and because I don't use Airconditioning in cars (it gives me respiratory issues).
Author:  Animal66 [ Sun Dec 23, 2012 10:40 pm ]
Welcome to the club!
Sounds like a fun money pit lol.
Look forward to seeing progess :)
Author:  two_OH_five [ Sun Dec 23, 2012 10:53 pm ]
Hi Dave
I take it you didn't remove the turbine from that turbo :shock:
If you're not going to switch fmic immediately I would consider removing what's there and giving it a thorough petrol clean out. Good chance there's some bits of compresssor wheel/housing in there
Author:  Sirius [ Sun Dec 23, 2012 11:20 pm ]
Welcome to the Club!
Author:  Nibbles [ Mon Dec 24, 2012 12:28 am ]
Hi & welcome.
I have a turbo that looks just like that on my shelf from my 185. It left a nice smokescreen on the A30 from the point it went until the next layby :lol: . Compressor side was unharmed so the engine survived (a bit longer).
Author:  Dave Dorson [ Mon Dec 24, 2012 1:04 am ]
Thanks all
The cold side looks fine. Oddly.
No, I didn't cause it. I bought it like this :), bought as "smokes a lot, unknown fault". It was cheap enough to warrant it :).
I'll take the exhaust off and check to see what's in there.. but I doubt anything is left of the turbine wheel. They shatter at the speed of failure and tend to just spit out of the exhaust in a load of pieces.
The FMIC and pipework is getting a thorough clean out, don't worry. :)
Author:  Jon9985 [ Mon Dec 24, 2012 11:10 am ]
Hi, the company I work for specialises in turbo rebuilds. Worth a call to see what we could do if your considering options about turbo.
http://www.advancedenginedynamics.co.uk
Author:  TrackToyFour [ Mon Dec 24, 2012 3:01 pm ]
Welcome to the DC Dave! Looks like a JDM ST205 going by the square number plates (and no sunroof?) You mention some of the mods but I would guess the previous owner(s) ran a boost controller at the very least. Have you had a good look to see what other mods have been carried out e.g. fuel, timing, ECU?
I've never seen a turbine shaft snap like that so it makes me wonder what caused it to fail in the first place. If it were my car I'd want to do a bit more investigation before bolting on a new/rebuilt turbo. The lubrication system would be a prime candidate for a forensic investigation followed by a thorough clean. Quite challenging to do thoroughly with the engine in the car.
Author:  Nibbles [ Mon Dec 24, 2012 3:59 pm ]
When mine went it was round a long sharp corner and I was travelling quite fast round it. I suspect oil surge, especially as I noticed start up big end rattle a few months later.
Author:  Dave Dorson [ Tue Dec 25, 2012 6:22 pm ]
Previous owner didn't know a lot about the car and tried to up the boost too much.
I've done a compression test, that's come back OK.
And yes it's a JDM WRC :)
It's fitted with a Greddy SpecII B EBC, front mounted stainless steel intercooler, and an HKS pillar mounted boost gauge.
Other than that, the engine is fairly stock.
There's an AEM FIC-6 in my stash ready to go on once I'm happy it's a strong engine, and I'll look at larger injectors and fueling/turbo upgrades as appropriate.
Author:  Dave Dorson [ Tue Dec 25, 2012 6:25 pm ]
Speaking of turbo.
I've an industrial garrett in my box of spares
It's from Cat/Perkins 6.0 diesel. Twin entry T3 housing, 0.68 hot side trim, 0.48 coldside trim, 71mm entry.
Based on the GT3571S :)
I'm currently looking into using it..or selling it and having my core turned into something.
Author:  TrackToyFour [ Tue Dec 25, 2012 9:05 pm ]
Hi Dave, I hope you don't mind me moving your thread to Modifications but there's quite a lot of useful info and background. Posts in the Greetings section are automatically nuked after a few weeks and it would be a shame to lose your thread.
Author:  Dave Dorson [ Wed Dec 26, 2012 2:45 pm ]
Thanks.
Moving it is fine :)
Author:  Sunny [ Wed Dec 26, 2012 3:04 pm ]
and welcome, truely one of the finest turbo damages i saw :lol:
Author:  UndaGrwnD [ Wed Dec 26, 2012 3:39 pm ]
welcome
i like the wheels!
Page 1 of 3 All times are UTC + 1 hour
