SARD 800cc injector problems http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=550 |
Author: | Diceman [ Tue Jan 31, 2006 9:37 pm ] |
Post subject: | SARD 800cc injector problems |
Has anyone fitted the low impedance 800cc injectors and got them to work OK ?? Had mine fitted over teh weekend and car does not start - with a power fc & map. Appears there is no fuel at all. |
Author: | krude [ Tue Jan 31, 2006 11:05 pm ] |
You sure they are low imp?? From what I understand they should be a direct drop in replacement. |
Author: | Kris [ Tue Jan 31, 2006 11:20 pm ] |
Quote: You sure they are low imp?? Yep, 3 ohms, pretty much the same as the stock injectors Quote: From what I understand they should be a direct drop in replacement.
Yes, this is pretty much everyones understanding! However, the theory is being a little tricky to prove one way or the other at present! |
Author: | two_OH_five [ Tue Jan 31, 2006 11:46 pm ] |
Quote: Yep, 3 ohms, pretty much the same as the stock injectors
[pedant] The one we measured was actually 2.5 ohms [/pedant] |
Author: | Diceman [ Wed Feb 01, 2006 12:04 am ] |
and MrT want to see between 2 & 3 ohms within their test procedure |
