Rear fog light converson on a st205 jdm http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=5220 |
Page 1 of 2 |
Author: | hally [ Sat Oct 29, 2011 7:27 pm ] |
Post subject: | Rear fog light converson on a st205 jdm |
hi i have a jdm 205 with the horrible hang down rear fog light i know people have changed this to a reverse light i was just wondering how to do this. i have the aftermarket fog light switch inside and also wanted to put the uk switch in is this possible cheers hally |
Author: | Kris [ Sat Oct 29, 2011 8:59 pm ] |
You can wire this into the rear light cluster - I used a diode and a switch - I'll see if I have the pictures ![]() |
Author: | V1 Rotate V2 [ Sun Oct 30, 2011 12:06 am ] |
Another one is to wire the centre brake light as the fog too ![]() |
Author: | hally [ Sun Oct 30, 2011 2:39 pm ] |
yeah mate if u could get the piks for me that would be great |
Author: | Kris [ Mon Oct 31, 2011 10:45 pm ] |
A few pictures of the modification I did to get the rear fog light into the light cluster... Picture of the original vs the later spec rear light cluster ![]() Another picture of the rear lights. Note that the connections into the housing are orientated slighty differently, but the original loom still fits without modification ![]() ![]() Picture with a small section of the loom wrapping removed to expose the wires... ![]() Modify the wiring similar to this - note the fused 12V supply. The rear lamp draws 1.7A. I fused the supply at 5A. ![]() This mod means you can run the inner lights as switchable fog lights, whilst keeping all the brake lights and without illuminating the "bulb blown" indication in the dash ![]() |
Author: | hally [ Tue Nov 01, 2011 6:30 pm ] |
Cheers for the pics mate but im i right in thinking tht you only need one reverse light on the backend for an mot? just i would rather just have the 1 fog and just use the origional bulb mount for the reverse light with the aftermarket switch wiring or am i barking up the wrong tree ? |
Author: | Kris [ Tue Nov 01, 2011 7:49 pm ] |
Hally, you're barking up the wrong tree ![]() All lights are available, the only difference is that the 2 inner lights become switchable fog lights. No lights are removed or altered |
Author: | banzaibaz [ Tue Nov 01, 2011 7:59 pm ] |
This is a tidy little mod Kris might have to do mine this way. |
Author: | hally [ Tue Nov 01, 2011 11:55 pm ] |
ok then so do i keep the fog light switch and the wireing that i have and just splice that into the diode? Im just not sure |
Author: | Kris [ Wed Nov 02, 2011 8:40 pm ] |
Quote: ok then so do i keep the fog light switch and the wireing that i have and just splice that into the diode?
Yes |
Author: | hally [ Thu Nov 03, 2011 6:29 pm ] |
i mite have to have a go at this but it defo should be a how to ! |
Author: | Kris [ Thu Nov 03, 2011 7:28 pm ] |
Quote: but it defo should be a how to !
I've put it in with the pile of stuff to be published on http://www.gtfours.co.uk |
Author: | hally [ Thu Nov 03, 2011 8:04 pm ] |
cool ill keep an eye on it got the dredded mot in a few weeks so ill have a go after |
Author: | Midnite [ Sun Nov 13, 2011 12:33 pm ] |
do you have a wiring diagram for this mod, i want to apply it to my st185 jdm |
Author: | hally [ Sat Dec 17, 2011 12:17 pm ] |
Any chance of a wiring diagram for this im definatly gona have a go |
