It is currently Sun Oct 05, 2025 9:56 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
PostPosted: Sat Oct 29, 2011 7:27 pm
hi i have a jdm 205 with the horrible hang down rear fog light i know people have changed this to a reverse light i was just wondering how to do this. i have the aftermarket fog light switch inside and also wanted to put the uk switch in is this possible cheers hally
PostPosted: Sat Oct 29, 2011 8:59 pm
You can wire this into the rear light cluster - I used a diode and a switch - I'll see if I have the pictures :)
PostPosted: Sun Oct 30, 2011 12:06 am
Another one is to wire the centre brake light as the fog too :) Kris's method sounds better though as you have all the lights working.
Per Ardua Ad Astra
∞ 1995 ST205 JDM ∞
PostPosted: Sun Oct 30, 2011 2:39 pm
yeah mate if u could get the piks for me that would be great
PostPosted: Mon Oct 31, 2011 10:45 pm
A few pictures of the modification I did to get the rear fog light into the light cluster...
Picture of the original vs the later spec rear light cluster
Another picture of the rear lights. Note that the connections into the housing are orientated slighty differently, but the original loom still fits without modification :)
Picture with a small section of the loom wrapping removed to expose the wires...
Modify the wiring similar to this - note the fused 12V supply. The rear lamp draws 1.7A. I fused the supply at 5A.
This mod means you can run the inner lights as switchable fog lights, whilst keeping all the brake lights and without illuminating the "bulb blown" indication in the dash :)
PostPosted: Tue Nov 01, 2011 6:30 pm
Cheers for the pics mate but im i right in thinking tht you only need one reverse light on the backend for an mot?
just i would rather just have the 1 fog and just use the origional bulb mount for the reverse light with the aftermarket switch wiring or am i barking up the wrong tree ?
PostPosted: Tue Nov 01, 2011 7:49 pm
Hally, you're barking up the wrong tree :P
All lights are available, the only difference is that the 2 inner lights become switchable fog lights.
No lights are removed or altered
PostPosted: Tue Nov 01, 2011 7:59 pm
This is a tidy little mod Kris might have to do mine this way.
PostPosted: Tue Nov 01, 2011 11:55 pm
ok then so do i keep the fog light switch and the wireing that i have and just splice that into the diode? Im just not sure
PostPosted: Wed Nov 02, 2011 8:40 pm
Yes
PostPosted: Thu Nov 03, 2011 6:29 pm
i mite have to have a go at this but it defo should be a how to !
PostPosted: Thu Nov 03, 2011 7:28 pm
I've put it in with the pile of stuff to be published on http://www.gtfours.co.uk
PostPosted: Thu Nov 03, 2011 8:04 pm
cool ill keep an eye on it got the dredded mot in a few weeks so ill have a go after
PostPosted: Sun Nov 13, 2011 12:33 pm
do you have a wiring diagram for this mod, i want to apply it to my st185 jdm
1990 JDM ST185 Grey.
ST205 head gasket.
ARP head bolts.
ST205 Koyo Rad. (almost)
Front mount intercooler.
Colder plugs.
3" decat pipe.
4 Branch manifold.
PostPosted: Sat Dec 17, 2011 12:17 pm
Any chance of a wiring diagram for this im definatly gona have a go
