Project Taurus http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=2908 |
Page 3 of 37 |
Author: | Sunny [ Tue May 12, 2009 7:10 pm ] |
Hi, they (TTE) use aluminium, but i can't manufacture it (welding, etc.) so i choose stainless steel pipes are safer especialy in a race-car with higher water pressure the downpipe is very close and also a reason for a pipe my friend told me that i can do the following to show the collapse action: - drive the engine good warm -> hot , so that you can be sure that the thermostat is far open - open the bonnet and open the throttle, try different revolution's up to 6000rpm or something - look at some hoses and see what they do i didn't do this becouse i belive his words greetz |
Author: | Sunny [ Tue May 12, 2009 7:53 pm ] |
Hi, today was the first try out of the swirlpot, a kingdome for a bit space but after i kicked the cusco tower-bar i have found a location [img][img]http://img100.imageshack.us/img100/2752/swirlpot.jpg[/img][/IMG] we also mounted a alu diff cushion, it give a bit more feedback from the back but also terrible vibration's in low rpm (but somehow it feel's great on the back ), not good for street but a good solution for rally [img][img]http://img100.imageshack.us/img100/803/aludiffplatte.jpg[/img][/IMG] proved and will replaced by a C-One Cushion i will sell it, if anyone is interested PM me greetz |
Author: | Sunny [ Sat May 16, 2009 1:26 pm ] |
Hi, i have to say, RHDJapan have the fastest delivery i have ever seen, bought at tuesday and got it today C-One Diff Cusion [img][img]http://img42.imageshack.us/img42/1421/conecushion2.jpg[/img][/IMG] and mounted, great no vibrations any more [img][img]http://img42.imageshack.us/img42/6900/conecushion.jpg[/img][/IMG] twice as thick as OEM or more the alu cushion is now on sale, if anyone is interested 50€ + delivery also fits ST185 and ST165 i think greetz |
Author: | Sunny [ Sun May 17, 2009 12:22 pm ] |
Hi, some testing was on the plan 4WD rock's [img][img]http://img269.imageshack.us/img269/7816/test2l.jpg[/img][/IMG] [img][img]http://img269.imageshack.us/img269/6661/testc.jpg[/img][/IMG] greetz |
Author: | Sunny [ Wed May 20, 2009 9:40 pm ] |
Hi, another part in direction target is done TTE Gruppe A Swirlpot airbox out [img][img]http://img200.imageshack.us/img200/3910/swirlpot2.jpg[/img][/IMG] close up of the situation [img][img]http://img200.imageshack.us/img200/4807/swirlpot3.jpg[/img][/IMG] and the target, sorry i forget to make pic's from the finished lines [img][img]http://img200.imageshack.us/img200/2045/swirlpot3b.jpg[/img][/IMG] and finished [img][img]http://img200.imageshack.us/img200/4871/swirlpot4y.jpg[/img][/IMG] i changed for a 1,5bar radiator cap for a higher boiling point, a nice part if i go on a raceway someday and then i proved the distance to the bonnet, with wash-sand to find the highest position (5mm distance to the bonnet) [img][img]http://img200.imageshack.us/img200/7357/swirlpot5.jpg[/img][/IMG] simple the best the next on my "to do list" is the jabsco pump, possible tomorrow but probably on friday becouse i'am thirsty greetz |
Author: | TrackToyFour [ Wed May 20, 2009 11:11 pm ] |
Looking good Is the TTE charge cooler available for sale from your supplier/manufacturer? |
Author: | Sunny [ Thu May 21, 2009 8:18 am ] |
Hi Don, thanks, i have a good and and a bad message, the good: nearly all parts are available becouse he bought the leftovers from TTE and the bad: very expensive - Chargecooler on top of engine 1250€ + 19% VAT + delivery greetz |
Author: | two_OH_five [ Thu May 21, 2009 8:56 am ] |
it will be interestig to see if anything changes - do you have any datalogging for inlet temps? I'm guessing your friend is Target Racing? |
Author: | Sunny [ Thu May 21, 2009 8:38 pm ] |
Hi, the hardest job is done Jabsco Pump first of all, i can yet mount a more restrictive front-radiator but with better cooling characteristics sorry, only two pictures becouse a want the job done [img][img]http://img34.imageshack.us/img34/9775/jabsco.jpg[/img][/IMG] less is often more, a wire-connector (hope this is the right english word) hold the relay in position, with silicone on the connector it is safe from weather Fuse, 25A [img][img]http://img34.imageshack.us/img34/1671/jabsco2.jpg[/img][/IMG] this pump work very well, i startet the pump with the ECU pin to evacuate the pump from air, as my friend cry "stop, stop, stop, da*n", and the engine was full of water and on the bad side is that i can feel very gentle vibrations on the brakepedal and cluchpedal when the pump works, i can't can use the rubber between bracket and OEM pump becouse there was no space any more, the jabsco pump fits perfect to the OEM bracket and now the wiring the 54-killer works great i use the "B" from the OEM Pump swiched power circle to swich my relay [img][img]http://img34.imageshack.us/img34/7104/pumpe.jpg[/img][/IMG] [img][img]http://img34.imageshack.us/img34/4138/jabscowiringz.png[/img][/IMG] PS.: i frogett to write that i have now nearly 2L water in my system, becouse of the swirlpot two_OH_five, i think you are right sorry, i have no datalogging, Haltech ECU will come next year i hope, without correct measurement it is very hard to give a answer, my first impression is -> it feels better greetz |
Author: | Sunny [ Wed May 27, 2009 5:38 pm ] |
TrackToyFour wrote: Alex, regarding the engine coolant, are you planning on fitting a swirl pot for that as well? The TTE setup seemed to rely on a stainless steel braided 'bleed' line from the high point of the curved hose which takes the hot coolant from the end of the cylinder head to the sealed radiator top tank. This bleed line was routed to the engine coolant header tank on the wing. I'm not sure how effective this was, it was certainly different to a conventional swirl pot.
Hi, Don, i will build the system possible in the end of summer09 but probably next year if i find space i found one reason for a different TTE system if i look pictures from standart swirlpots http://images.google.at/images?hl=de&q= ... a=N&tab=wi possible waterflow and space, not sure greetz |
Author: | TrackToyFour [ Wed May 27, 2009 11:43 pm ] |
Not sure if you've seen this from the Fensport (Tony Charles) ST205 modified cooling system Swirl Pot Header Tank |
Author: | Sunny [ Thu May 28, 2009 3:06 pm ] |
Hi Don, it is not the first time is see his car, but the first time i see quality pictures from his engine bay i think my system will be different becouse, there is not many space left to do list: - try to mount a tank in front of the ABS system - 2 or 3 points for air escape (radiator top left and right, and in the water top hose) - MR2 Turbo thermosthat housing (to connect the tank) this is my first plan but there is still R&D left, i will see cannot do the project this time, becouse is have to buy new Toyo's for the trip to switzerland greetz |
Author: | Sunny [ Wed Jun 03, 2009 8:12 pm ] |
Hi, car is crashed against a stone in a rally action on weekend destroyed is on the left side: super strut, damper, wheel, fender, bumper intercooler hoses, resonace-box (not important) hope to be back on the road again as soon as possible i learned that it is not cool to drive in wet grass and the good is that i have now space for a water-tank under the left fender greetz |
Author: | Sirius [ Thu Jun 04, 2009 12:55 am ] |
Sunny, sorry to hear this Hope your car will be repaired in time for the swiss trip. |
Author: | Muddy Water [ Thu Jun 04, 2009 11:50 am ] |
Oh no sorry to hear you've had a smash. Hope you are able to repair and get it back on the road soon. |
Page 3 of 37 | All times are UTC + 1 hour |
