1990 White UK ST185 Project DTM http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=2782 |
Page 3 of 8 |
Author: | Muddy Water [ Sat Sep 04, 2010 8:24 pm ] |
Quote: Curious as to where your jacking points will be?
Able to retain standard jacking points |
Author: | Muddy Water [ Sat Oct 23, 2010 5:43 pm ] |
Just a couple of pics as an update: |
Author: | toyokid [ Sat Oct 23, 2010 6:48 pm ] |
Hello Nige Sorry if it has been covered before but have you considered fitting a complete 205 back end? You look as if you will have all the width available? Stephen |
Author: | Muddy Water [ Sat Oct 23, 2010 8:09 pm ] |
toyokid wrote: Hello Nige
Sorry if it has been covered before but have you considered fitting a complete 205 back end? You look as if you will have all the width available? Stephen I didn't actually consider a 205 back end... I felt it was going to be much easier with the Carcept 185 specific rear bumper - it gave me the style I was looking for, it's an excellent fit, fixings are all in the right places and only "minor" modifcations to bring the rear out to the arches. BTW: The rear bumper where shown in the pics above actually has a metal plate fibreglassed in allowing it to bolt to the arch, that way the rear bumper can be removed easily and in one piece. |
Author: | Muddy Water [ Sun Jan 16, 2011 12:14 am ] |
Quick update... Bodywork fabrication very nearly done, all windows and windscreen out (including trims and surrounds). We're near as dam-it ready for primer - just waiting for a slot at the painters |
Author: | alex237 [ Sun Jan 16, 2011 12:20 am ] |
i think the scoop needs to come forward a tad,lol |
Author: | johnyboy1976 [ Sun Jan 16, 2011 12:27 am ] |
Looking good mate |
Author: | Meurz [ Mon Jan 17, 2011 2:24 am ] |
Do you have a close-up of the bootlid fitment Muddy? They are sold as perfect fitment. Perfect is 100% correct, but looks like there are panel gaps? Hope not (I have one as well) |
Author: | Muddy Water [ Mon Jan 17, 2011 2:27 pm ] |
Quote: Do you have a close-up of the bootlid fitment Muddy? They are sold as perfect fitment. Perfect is 100% correct, but looks like there are panel gaps? Hope not (I have one as well)
Knowing you from previous conversations you're not going to be particularly happy mate. This is a genuine SEIBON CF ATA Bonnet and is not a 100% correct fitment. Rear fitment across scuttle panel is good. Fitment to hinges is good. Shut lines along each wing is good, that is, even and uniform. However, I feel there is a little too much of a gap. There is also a bit of a gap between the rear of the headlight units - this may be because I am using the MR2 headlight conversion. Front shut line was a bit out but this may be because I not using the CF strip that goes between the headlights. We actually raised the whole of the front bumper, to compensate for not using the CF strip, to align with the bonnet and get a smooth transition. Having said all that it may be that yours fits better as you are fitting to oem bumper and headlights. |
Author: | Gary ST165 [ Mon Jan 17, 2011 9:36 pm ] |
Quote: Do you have a close-up of the bootlid fitment Muddy? They are sold as perfect fitment. Perfect is 100% correct, but looks like there are panel gaps? Hope not (I have one as well) Muddy Water wrote: Knowing you from previous conversations you're not going to be particularly happy mate.
This is a genuine SEIBON CF ATA Bonnet and is not a 100% correct fitment. Rear fitment across scuttle panel is good. Fitment to hinges is good. Shut lines along each wing is good, that is, even and uniform. However, I feel there is a little too much of a gap. There is also a bit of a gap between the rear of the headlight units - this may be because I am using the MR2 headlight conversion. Front shut line was a bit out but this may be because I not using the CF strip that goes between the headlights. We actually raised the whole of the front bumper, to compensate for not using the CF strip, to align with the bonnet and get a smooth transition. Having said all that it may be that yours fits better as you are fitting to oem bumper and headlights. ? Rene mentioned bootlid panel gaps. where was the tail gate bought ? |
Author: | Meurz [ Mon Jan 17, 2011 10:59 pm ] |
Indeed Gary. |
Author: | Muddy Water [ Tue Jan 18, 2011 2:43 pm ] |
...really ought to leave the computer well alone after a drink or too The boot lid is actually a very good fit. There is only 1 place either side where there is a slight gap which will be taken out when the rear screen is fitted. I'll see if I can dig out some pics - actually the first 2 pics at the top of this page show the gap I'm talking about. |
Author: | Muddy Water [ Sun Feb 06, 2011 10:44 am ] |
Quote: ...where was the tail gate bought ?
Wolfiehere/Alex237 from the OC. |
Author: | Muddy Water [ Thu Feb 10, 2011 12:10 pm ] |
UPDATE Bodywork completed Car ready for stage 1 paint, that is, dropping the car off to the painters in Basingstoke this Friday afternoon for it to be prepped, sealed and etch primed. Once complete, from there it goes to the roll cage manufacturers (also in Basingstoke) for the roll cage to be made and fitted. Timescales look as if they will have it next Wednesday for a week. |
Author: | Sirius [ Thu Feb 10, 2011 1:41 pm ] |
Nigel - who are you using for the paint? |
Page 3 of 8 | All times are UTC + 1 hour |
