http://gt4dc.co.uk/forum/
Loom & Ecu Plugs - possible source found
http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=2417
Page 1 of 3
Author:  Diceman [ Fri May 30, 2008 9:23 pm ]
Post subject:  Loom & Ecu Plugs - possible source found
Taken from the Mr2 & Alltrac guys:-
http://www.onlinecomponents.com/product/2770890/
http://www.onlinecomponents.com/product/2770894/
http://www.onlinecomponents.com/product/2770899/
toyota ECU plug part #'s for custom harnesses
female receptacle is amp/tyco part # 174518-7
the male plugs are part #'s 174514-6 (16 pin), 174515-6 (22 pin), and 174516-6 (26 pin), with contacts being part #'s 173631 (large) and 173716 (small). you'll need 16 of the larger and 48 of the smaller ones.
www.onlinecomponents.com stocks all these parts.
the female plug costs ~$6
the male plugs cost ~$1 each and the pins are about 4-5 cents each and they have no minimum order.
Thought you may find this useful :-)
Author:  Kris [ Fri May 30, 2008 10:42 pm ]
Great find! This will make a loom adaptor from a stocker to your fantastic ECU a breeze! :)
Author:  TrackToyFour [ Sat May 31, 2008 11:52 pm ]
Interesting find JP. According to Mark Harrison at Owen Development the Subaru Impreza uses the same type of plugs. I think that's what he used to make up my loom adapter for my MoTeC M4 to OEM ST20 engine loom.
Author:  datajon [ Tue Jun 03, 2008 11:21 am ]
good find, have you ordered anything from them
Author:  Diceman [ Tue Jun 03, 2008 1:22 pm ]
Not Yet DJ. I will order one set to confirm they are correct and then maybe run a group buy as there seems to be fair amount of interest?
Author:  datajon [ Wed Jun 04, 2008 1:27 pm ]
Hi JP.
There does seem to be a minimal order as displayed below from the shopping cart, not that its a major problem.
Minimum Order Not Reached
Onlinecomponents.com has a minimum order total of $35 for orders shipping within the US and $100 for international orders.
You may continue with your order, but a surcharge will be added to bring your order to the minimum.
Proceed with $26.40 surcharge
I for 1 will be up for ordering 3 complete sockets with terminal pins and as 3 sets of each required plug with pins.
JP if you are going to place an order soon, could i add my order onto yours, however if you are not placing an order shortly then I shall place the order asap and add on what ever you require.
would be good to go ahead real soon , have plenty of jobs that required the above connectors making my life that little bit easier using new.
Author:  Diceman [ Wed Jun 04, 2008 1:35 pm ]
DJ,
I am not going to get a chance to sort this out before I bugger off to Le Mans this weekend.
If you are hapy to order I will take 2 full sets (sockets/pins & connectors) and Steve will take 1 full set. I can paypal you money for all three sets or send a cheque over m8.
Otherwise I will organise a group buy on my return from le mans in circa 2 weeks.
Author:  datajon [ Wed Jun 04, 2008 1:50 pm ]
No worries JP, will get an order in adding the extra plus a few more just encase any one esle wants one.
they don't show stock on one of the plugs, will fire an email over to verify this
have a good time at Le Mans, tis a great place.
Author:  Diceman [ Wed Jun 04, 2008 3:07 pm ]
Cheers Jon.
Should be good - maybe one of the GT4DC club biggest attended events :-)
Author:  datajon [ Thu Jun 05, 2008 11:40 am ]
problem with Onlinecomponents seems down for scheduled maintenance.
Author:  Diceman [ Tue Jun 24, 2008 10:48 pm ]
Oh bugger - you had any luck since then DJ or do I need to have a go?
Author:  datajon [ Wed Jun 25, 2008 12:12 pm ]
Hi Jp, yes all sorted, just a few little things.
part number 173631 comes in 5 types, only 2 in stock, dimension appear to be the same, price is not. just a few 1/4 cents.
part numbers : 173631-1 & 173631-6 both dimensions are # Wire Range = 0.50-1.40² [20-16] mm [AWG]
# Insulation Diameter = 2.01 - 2.59 mm..
part no. 174518-7 AMP / TYCO 10 back order (8 wk).
ordered both sets of pins that came up under part no 173631
shipment of parts in stock was 7-14 days, not long now, as for the female connector the major part i need 7 weeks away.
ordered 10 complete sets.
Author:  Diceman [ Wed Jul 16, 2008 7:14 pm ]
Any luck DJ?
Had a bit of a search and both Farnell & RS components are distributors but don't have full stock!
http://ecommerce.tycoelectronics.com/wh ... egion=0401
Bloody female connector always causes issues!
Author:  datajon [ Sat Aug 02, 2008 9:22 am ]
hi Jp, everything has been ordered just waiting for the main female connector to become in stock once its has they will send everything.
Author:  Diceman [ Sat Aug 02, 2008 10:23 am ]
Nice to see you are at least back in front of a computer m8. Sounds like you have been in the wars buddy. Hope you are on the mend m8 :-)
