Track Weapon Chassis http://gt4dc.co.uk/forum/viewtopic.php?f=1&t=2189 |
Page 1 of 27 |
Author: | TrackToyFour [ Sat Dec 29, 2007 5:31 pm ] |
Post subject: | Track Weapon Chassis |
Its been a while since I reported on the Track Weapon project. I've decided to start a separate Chassis topic as the engine one is probably big enough to slow down most peoples browsers as it loads the pics ![]() ![]() Build activity over the next year will not be continuous as there will need to be a fair number of bespoke components manufactured. This is not an Evo or Impreza where there are loads of parts available off the shelf but hey, thats why I'm doing this in the first place ![]() JEMS were quite impressed with the Toyota design and also the general condition of the shell and say it is better than many they have had to work with. They are even thinking of buying an ST205 themselves as a project car! On another positive note it turned out to be quite easy to source a new roof panel and the coachbuilders will do the specialist job of removing the old roof (including the sunroof) and fitting the new one once the roll cage has been fabricated in-situ. Exterior Front ![]() Nose ![]() Rear ![]() Interior Front ![]() Rear ![]() Side ![]() Door ![]() Jack Compartment ![]() Aerial Compartment ![]() Rear Suspension Turret ![]() At JEMS More dismantling ![]() Front View ![]() Engine remains ![]() ![]() The original 120,000 mile engine showing evidence of twelve years on salty UK roads ![]() Interior view after JEMS had successfully removed the heater/air con units and associated pipework. The cross bar visible in this view will be replaced by part of the roll cage ![]() |
Author: | robbiemcvee [ Sat Dec 29, 2007 9:02 pm ] |
thats great Don, i'm really looking forward to seeing your project develop. The chassis is one of particular interest as i will be looking to develop my chassis and handling rather than going for more power. There was quite a bit of bracing on Mutley - are you planning to brace the front at all? This does look like it's going to be an interesting year ahead! |
Author: | Kris [ Sat Dec 29, 2007 9:42 pm ] |
Great pictures Don, thanks in advance for sharing your hard earned and expensive knowledge! |
Author: | Loosey [ Sat Dec 29, 2007 10:15 pm ] |
I know the end result will be more than worth it, but it is hard to see stormy blue stripped down past his bare essentials! |
Author: | TrackToyFour [ Sun Dec 30, 2007 1:38 am ] |
Rob, the front suspension turrets will be braced to the front of the rollcage. This may include triangulating to the front rollcage crossmember as per the WRC setup. CDS will be used for the cage as T45 is more likely to break or fracture. This will incur a weight penalty of around 15kg but I'd sooner play safe with something as important as a rollcage, particularly as it will be carrying the suspension loads. The plan is for the front and rear pressed steel subframes to be replaced with spaceframes. This should reduce the weight significantly and improve the rigidity. Superstrut will be junked for McPherson struts and fully adjustable wishbones and tie rods. Again this should save a lot of weight. Kris, you know you are always the first to hear of my secret squirrel ideas ![]() Loosey, the toughest part was stripping the interior of Stormy Blue, particularly since he's been 'in the family' for over ten years. I felt really guilty ![]() |
Author: | two_OH_five [ Sun Dec 30, 2007 10:44 am ] |
Pedal box conversion?? Interesting to note that you don't have the floor mounted B pillar bracing |
Author: | robbiemcvee [ Sun Dec 30, 2007 2:17 pm ] |
what are you doing with the adjustable suspension already on it - do you want a buyer - mine is starting to leak.. |
Author: | TrackToyFour [ Sun Dec 30, 2007 3:56 pm ] |
two_OH_five wrote: Pedal box conversion?? Yes of course, twin master cylinder and adjustable bias via completely re-plumbed front/rear split brake lines. Probably going for AP front discs and calipers while retaining stock rear calipers and discs. From experience it is possible to warp the rear discs with the standard brake setup. Hopefully the adjustable bias will take some of the load off the rear. Quote: Interesting to note that you don't have the floor mounted B pillar bracing Pics please ...is this a face lift mod? There is a surprising amount of flex in the shell to the extent that its quite easy to twist the door frame if you jack the body unevenly. This makes it difficult to close the door. All this will be sorted by fitting the roll cage as this will take all the suspension loads. [/quote] |
Author: | TrackToyFour [ Sun Dec 30, 2007 4:01 pm ] |
robbiemcvee wrote: what are you doing with the adjustable suspension already on it - do you want a buyer - mine is starting to leak..
Go on then ![]() ![]() ![]() |
Author: | two_OH_five [ Sun Dec 30, 2007 6:04 pm ] |
You can just about make it out here. There are better photos I've seen, still looking Photo Courtesy of MrBarry on the OC ![]() |
Author: | two_OH_five [ Sun Dec 30, 2007 6:14 pm ] |
Found the little tinkers Removed from a WRC which was broken - hence I'm suprised it's not present on yours I wonder if it was one of the few rumoured Grp N "production" cars Somewhat tortuosly via Gary from Mr B again ![]() ![]() ![]() From HERE |
Author: | TrackToyFour [ Sun Dec 30, 2007 10:47 pm ] |
Hmmm, interesting. I'll need to check my white ST205WRC in the morning. TBH I'd have thought that these braces were fitted more as an afterthought on later production models but I guess that would mean they were non-WRC fittings. Have I just done a Carter loop on this ![]() ![]() |
Author: | Sirius [ Sun Dec 30, 2007 10:54 pm ] |
Excellent pictures Don ![]() Must have been really hard - I wouldn't want to strip my car back that far, although like you say - its saving the car from a worse fate. ![]() |
Author: | robbiemcvee [ Sun Dec 30, 2007 11:40 pm ] |
thanks Don, yes please let me know? |
Author: | two_OH_five [ Mon Jan 07, 2008 10:38 pm ] |
Heeee heeee, Guess what strengtheners I've got ![]() ![]() I rather suspect they're part of the additional side impact system rather than chassis strengthening though ![]() |
Page 1 of 27 | All times are UTC + 1 hour |
