This is the topic related to
Engine rebuild now done right:
http://gt4dc.co.uk/forum/viewtopic.php?t=1880
This post is to show what can happen to an engine rebuild and how the customer is allways the one who has to pay for it. It is meant to maybe prevent someone else to face the same problems i had to face.
Ok now here we go:
first i would like to point out something for everyone who is planing to do a rebuild:
If you do want to rebuild your engine use only one tuner or company ! Or if you have to work together with more then one tuner... get every delivered part checked by a technical expert!
The thing is company a will otherwise accuse company b and the other way around. This means you could end up with a damaged engine and still have paid the full price for it. Believe it i went through it!!!
It all went well until we realised during a TD06 Turbo Upgrade that the engine seems to suffer from some slight problem. (If you ever encounter a problem like this: get it checked straight away!!)
When we examined the engine we found out that some cylinderwalls had slight scratches. But big enough that just honing and fittig bigger pistonrings was not possible (especially with the plan in mind to raise the pressure)
After reading a lot about the problems between cyinder 2 and 3 when boring out the block i decided to fit Chrome Moly ductile sleeves by CHrisK. Then i questioned myself why only stay near stock when i have to spent so much money. so we went for the full range: CP Pistons with ceramic top coating, Pauter conrods, Carbon clutch...
We nearly spent 1 year resourcing all the best parts which could be used.
Further more i decided to send my cylinder head with the new JUN Camshafts to ChrisK to get a full street port job with shimless buckets, titanium retainers...
It took a while but finally we received all the parts and the midified head beside a new Garrett GT35R Turbo.
Then it was my decision where to get the job of putting all together done. I wanted to get to ex TTE Mr Breuer. But he adviced me to not travel the long way to him as a good engine builder could easily do this job.
I found a company in Germany ehich saved me 300km but finally cost me my engine
Even that they had 35 years of motorsport tuning experience especially in tuning a 3SGTE engine they kind of messed up.
Here are some pics before i explain what happened.
