It is currently Sun Oct 05, 2025 12:27 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 46, 47, 48, 49, 50, 51, 52 ... 56  Next
PostPosted: Sun Mar 16, 2014 11:50 pm
Shame it doesn't fit the Gen 3 :cry:
http://www.atsracing.net/Parts/Details/E-OILPUMP
High Quality
Same manufacturer as the OEM Toyota pump
Lower cost than OEM Toyota pump (yes, it really is a better pump at a cheaper price)
Increased pump volume
Beware of imitations. This is not a stock pump with a couple of washers jammed in the relief spring.
Gen1/2 only. Will not fit Gen3 or Gen4 engines.
PostPosted: Mon Mar 17, 2014 3:39 pm
you can use a beams blacktop pump, but you would also need the oil pan nr.1 (alu) from a gen.4 (crank position sensor area)
viewtopic.php?f=13&t=5300&p=40958&hilit=beams+oil+pump#p40958
idle ~3bar, and nearly every time the maximum of ~6bar
PostPosted: Mon Mar 17, 2014 8:41 pm
high flow oil pump has landed :)
so guess what im doing over the next few days ;)
PostPosted: Mon Mar 17, 2014 8:45 pm
I have, and will be running, a Toga High Volume Oil Pump (OPTO25C-HV) :D
http://www.importperformanceparts.net/imports/toga_oilpumpstoyota.html
PostPosted: Mon Jun 02, 2014 6:36 pm
little up date im now running my new racing mounts Image
witch I all so make and sell for all the gt4's
PostPosted: Wed Jun 04, 2014 9:15 pm
cheers bud
http://youtu.be/flK8RXt5lUs
http://youtu.be/Z0giMjqhtpY
http://youtu.be/QZeOH-XogrY
http://youtu.be/YmH3QWH6KnE
PostPosted: Wed Jun 04, 2014 11:47 pm
Looking good! :)
PostPosted: Sat Jun 07, 2014 12:58 pm
few more photos from Prescott
PostPosted: Wed Jul 30, 2014 8:45 pm
Been doing a bit of work to the Beast and think I have found out why im was still getting a bit of knocking from the rear and felt a bit lose on the rear end even with the poly diff munt fitted, took the diff subframe hanger out and as you can see the bushes have well and truly gone ;( so will be changing them for some nice BRD race bushes :) and as I was there I have all ready fitted the BRD ally diff mount ready :) But this just shows how important it is to replace 20+ year old bushes.
BRD ally diff mount all in ready
just starting on the race rear diff mount hanger bushes
just finished of the rear diff hanger bushes just need to fit it all now for testing
all powder coated ready to fit back in :) next on the list are rear subframe bushes but that a job for over the winter
PostPosted: Tue Aug 05, 2014 7:04 pm
well Diff Subframe is all fitted and back on the road and all I can say is my god lol the back end of the car feels like it is attached to the car lol, very impressed so far, there is a little bit of noise coming from the back but then mine is fully stripped out but apart from that very happy so far so just making a start on a second set and staring on the rest of the bushes for the rear subframe
PostPosted: Sun Oct 26, 2014 1:14 pm
just found this photo of me competing in the Beast in July at shelsley walsh
in car footage of competing today
http://youtu.be/tySgf93wUzI
pics from a photo shoot with JANPANESE PERFROMANCE
PostPosted: Sun Oct 26, 2014 1:15 pm
Dyno day at Surrey dyno and very happy after being road mapped this is the first dyno its had,
Boost
Fuelling
http://youtu.be/COb1Q0q4bZg
PostPosted: Sun Oct 26, 2014 4:08 pm
Nice flat torque curve must make it very nice to drive.
Who actually did the ECU mapping? Surrey usually supply the equipment and you do it yourself or bring your tame mapper with you.
PostPosted: Sun Oct 26, 2014 5:39 pm
yes very nice to drive and all most drives like and N/A till the boost comes in, Greg from Protuner does all my mapping for me, and this is the fist time it been on a dyno since its been road mapped,
PostPosted: Wed Aug 19, 2015 8:27 pm
right bit of an update but not a good 1 :( was out in the car a few months back for a nice drive and things did not go well, all of a sudden after a hard blast I go a full on smoke screen out the exhaust and I mean full on, so pulled over to see what had gone wrong, found some oil in the engine bay that seem to be coming out the gasket on the turbo to down pipe :? so checked the oil level and found the oil was on the very bottom tip of the dip stick not good, so then had a look in the back box and found all my nice clean oil in it, thought that's it engine has gone, so got the car trailer home Big thanks to Wolfy for that :thumbsup: so on Saturday started to strip the turbo off to have a look to see what had gone wrong, took the intake pipe off to see some oil in the intake turn it over to drain it out and a Nut fell out of it :dunno: *bleep* I thought then saw what Nut it was, its the only part of the build iv not made or built my self and it brakes
bloody turbo impeller Nut had come off :( so then had a quick look at the impeller as was thinking the worsted, but found it was all still in 1 piece with no makes on it at all
so took the turbo off to have a better look, and found the rest of my oil
by the look of it I have been very lucky and the engine is all ok, just the turbo seal and bearings have gone,
so next I need to get the exhaust off and drain the oil out both the box's as they are full, and then I need to look at ether I have this rebuilt or just got all out and get a better turbo that will make the 400-450bhp but with a quick spool for competing,
so as im waiting to sort the turbo out, im now making my intercooler pipe work better by making it a full hard pipe set up, just done some mocking up today of how it will go, this is the cold side
as you can see at the moment I have the samco joints witch I want to get rid of
just need to weld it up now then onto the next part
bit more work done on the hard pipe set up, cold side nearly finished just 1 more pipe to weld in place
well found all the oil, this is what happens when your turbo oil seal goes big time
this just came out the exhaust pipe, I have 3 box's to take off and drain yet
url=http://s521.photobucket.com/user/gt4louis/media/gt4louis189/IMAG0501_zpsqjdm0ob1.jpg.html]Image[/url]
crank is out
Crank out and some signs of light scoring, so its of to the machine shop its goes
bit more pipe work for the Beast 4" intake pipe to the turbo that should help it get some air :)
new crank and bearings all fitted
just waiting on new seal for oil pump and an crank now
cold side hard pipe is back after being powdercoated
pretty :) just shim gaps to sort out next
so while im waiting on a custom gear box I have been doing some fabrication work on Decat pipes with Flexi section in ,
so started with a Jig to make the decat up on
bottom parts of the Decat done
top half done
all ready for flexi
flexi fitted in all nice
the fun bit
all done
all cleaned and polished
the inside of the pipe
first test fit of the flexi decat
all good so far but it may need a tweak hear and there, till im happy
new clutch thanks to GT4-play https://www.facebook.com/pages/GT4-Play ... 77?fref=ts
just the gear box now and I can put it back together
