It is currently Sun Oct 05, 2025 10:02 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 31, 32, 33, 34, 35, 36, 37 ... 56  Next
PostPosted: Mon Dec 26, 2011 4:42 pm
just finished the block and it is now all ready to be rebuilt:)
PostPosted: Mon Dec 26, 2011 6:39 pm
manifold is now all finished ported and matched :) just need to paint it up
here you can see where i smothed the porting out
PostPosted: Thu Dec 29, 2011 5:48 pm
finished the new side feed manifold today :) it now all ready to fit to the head
hanging up to dry
here you can see where I have modified the intake so that I can run the idle up valve
and now all ready with the 185 throttle body fitted
here you can see the 2 temp sensors for the ecu and my charge temp gauge
PostPosted: Thu Dec 29, 2011 9:40 pm
Side feed looks good all prepped up in white. I shall be interested to hear how it performs on the car.
PostPosted: Thu Dec 29, 2011 10:02 pm
me to lol
PostPosted: Fri Jan 06, 2012 9:39 pm
manifold is now fitted to the head:)
hear you can see the plate I had to make so that I can use the idle up valve and for there to be a back plate for the air bypass
PostPosted: Sun Jan 15, 2012 12:09 pm
not rely done much this weekend, but got eh flywheel and crank back :)
the flywheel has been lightened and balanced you can see where it has been refaced for the friction plate
and here you can see where it has been lightened and balanced
and the crank has been balanced to they said it was way out of balance so good job I had it done, you can see where they have drilled it out to balance it up
I have now all so weighed all the rods and piston to mach them all up and as you can see all the pistons weighed the same and so do the rods :)
now all i have to do is put it all back to gether :)
PostPosted: Sun Jan 15, 2012 7:29 pm
ok so I lied lol went out and did a bit more
using the pastigauge I fitted the bearings and crank,
here you can see the plastigauge
then torque everything down
then take capos off to see how much the plastigauge has spread
then using the gauge see if everything is to tolerance
and every thing looks fine to me all with in tolerance so i refitted all the caps and torqued evvery thing back up:)
now its ready to have the conroads and pistons fitted next weekend :)
PostPosted: Wed Jan 18, 2012 7:27 pm
Great to see DIY and also great to see useful pictures that'll help everyone understand a bit more!
PostPosted: Thu Jan 19, 2012 8:09 pm
did a bit tonight got all the pistons fitted to the rods
and fitted the new oil pump
with any luck ishould have the block all built back up by the end of the weekend :)
PostPosted: Sat Jan 21, 2012 7:15 pm
right we had a very good day to day with the help of Dug and Rich :) big thanks to both of you,
the fist mod of the day was to fit a latch to the shed door as it was flowing open all the time with the wind, so as in good old mixer moding style I did this :)
1 turbo gasket later
then it was onto the build, we started by gaping up all the rings for each piston
here you can see the ring being fitted into the block so that we can use the feeler gauges to check the gap
the rings needed the gaps setting so got the gap setting tool out
then repeat for the rest of the pistons
after all the ring gaps were set up build up the pistons and install into block
after all the pistons were fitted in to the block then we fitted the ARP head bolts to the block
and fit head and torque down
and you end up with engine block back to gather
so I only have a few bits left to do and that is the block all ready to go back in the car :)
PostPosted: Sun Jan 22, 2012 2:35 pm
few more bits fitted
PostPosted: Sun Jan 22, 2012 4:12 pm
Nice work. 8)
ST185 CS #1845
PostPosted: Sun Jan 22, 2012 8:40 pm
Very nice indeed very informative.
PostPosted: Sat Jan 28, 2012 2:54 pm
update i have now finished the engien block :) and it is all ready to ge back into the car.
just nee to get the grear box and turbo done now
