It is currently Sun Oct 05, 2025 9:57 pm
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 37  Next
PostPosted: Thu Jun 04, 2009 5:31 pm
charity is not essential, i know the risk's and it was my wrong :)
damage sum = 600€ to 700€
but i also have to buy a new compomotive and a set of tyres, another 900€
i will repair it, for sure 8)
i'am probably back on the road at the end of next week.....such a long time :lol:
the swiss trip is safe, i want to meet my english folks 8) :D
PostPosted: Thu Jun 11, 2009 11:51 am
back on the road again :)
[img][img]http://img268.imageshack.us/img268/3232/backontheroad.jpg[/img][/IMG]
i only miss the straight SS-arm with the joint like a 8, becouse i can apply the suspension too much and then i need a track set, we made this only thumb x pi :lol:
but works good without any vibration only the steering is not ok
PostPosted: Thu Jun 11, 2009 10:15 pm
You need to wash it now! :)
PostPosted: Fri Jun 12, 2009 1:43 pm
but why.....? dirt makes the car sexy :lol:
washing the car was my first action, but my second action was a ride on gravel :lol:
PostPosted: Fri Jun 19, 2009 4:29 pm
comming soon,
- sard breathing tank
- modified water outlet elbow (tip from TTE)
hope that i can start the project next weekend, as we have so much work in our company, but must be done before the swiss-meeting
PostPosted: Fri Jun 26, 2009 7:32 pm
project "breathing tank" is harder then i thought, i found only one position where i can fit the tank, and this is on the OEM strutbrace next to the intercooler swirlpot, this means that i need very long lines and is not a good solution.....as two of my opinions are "less is more" and "the uncomplicated way is the best way"
but i can't stop the develoment becouse i ordered 6m earl's hoses for this project (people who use earls parts know what i mean)
what do you think about?
PostPosted: Fri Jun 26, 2009 11:49 pm
I presume the 'breather tank' is an engine cooling system header tank? If so, have you worked out how the water expansion will flow into the tank and how it will drain back into the main system when it cools?
PostPosted: Sat Jun 27, 2009 7:28 pm
sorry, yes is speak about a header tank
here a sketch how it works
air collects in the radiator neck and flow up to the header tank, and water flow back to the cooling system, the line from the breathing tank to the reservoir compensate the water level like the OEM sytem
PostPosted: Wed Jul 22, 2009 7:21 pm
thanks God, i got my new (old) wheels on the car, the last damage is repaired
i also mounted the SARD breathing tank on weekend, this was the only position i found
(TTE style mounted :lol: )
i hope that i get the lines i'am waiting for until weekend to finish the work
and now there are only two bigger mods i plan and some smaller before i build the engine, or let'em build
1. carbon propshaft
2. Sparco Milano's (the OEM seats are terrible to my back)
PostPosted: Sun Jul 26, 2009 1:26 pm
@ Wolf
i was yesterday on a rally-cross, new peak oil themp. is 108°C
PostPosted: Sun Jul 26, 2009 3:11 pm
That's not a bad temp if you are using good oil
On track I back off when temps exceed 120C. The Silkolene oil I use is rated to higher than this
PostPosted: Mon Jul 27, 2009 9:41 am
FYI
My Engine Oil Cooler and thermostatic oil filter plate are now fitted.
Oil temps - maximum @75/80 deg C
Water temps - maximum @80 deg C.
Very pleased with these figures. :D - some 20 deg C lower than previously.
These have been seen on my gauges while travelling to and from work.
This includes local traffic and some motorway driving.
I will be out on track next weekend so it will be interesting to see what temps I'm getting then.
PostPosted: Mon Jul 27, 2009 4:20 pm
there is no problem with the oil, i often saw 120°C and + themp's last year, before i changed to a pipe
Muddy Water, i'am also interested
PostPosted: Mon Aug 03, 2009 10:55 am
OK, here are the readings that I took from my sprint series round.
Oil temps - maximum @90-95 deg C
Water temps - maximum @95-100 deg C.
I have to say that I'm very pleased with these figures. :D
PostPosted: Mon Aug 03, 2009 11:34 am
that's very good, what radiator core was it?
my new peak oil themp is 111°C after some hill-climbs
last year: 120°C and more
