It is currently Mon Oct 06, 2025 3:29 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 26, 27, 28, 29, 30, 31, 32 ... 37  Next
 Post subject: Re: Project Taurus
PostPosted: Wed Jan 16, 2013 1:54 pm
a small mod to the camgears, two holes and a tool to adjust the gears easily
PostPosted: Wed Jan 16, 2013 2:40 pm
Question
Are those gears balanced?
The pattern of drilled holes doesn't look very symmetric to me
PostPosted: Wed Jan 16, 2013 4:34 pm
i'am not sure but even they are my holes are cnc drilled so it still balanced
if you mean the many holes on the outer part, this ones are that one i'am able to set the degrees with the granade pin
PostPosted: Wed Jan 16, 2013 11:02 pm
i'am pretty sure i asked this some time ago, but has anyone good pictures of the camshafts with correct mounted timing belt on so that i can see the cam lobes, possible also from the end of the shafts so that i can see the slots?
i have no mark on my cams and i'am not 100% sure about i set it correct :lol:
best regards
Alex
PostPosted: Wed Jan 16, 2013 11:51 pm
Does this help? It is from a 215 engine so you should be looking at the exact same thing
You can see on the pulleys the indfent (and white tooth on pulley that I marked for clarity)
You can also see on the aluminium housing above eacvh pulley there is a small pointer
When the crank pulley is exactly TDC then the cam pulley indents and the cam cover pointers should be exactly in line
If you don't have the index mark on your can pulley best I can suggest is remove them and refit the OEM ones. Mark the can with engineers die when everything is aligned and you can then align your aftermarket pulleys using the camshaft marks
PostPosted: Thu Jan 17, 2013 12:57 am
I can take some pics of the Gen3 3S-GTE engine I am currently stripping. The cam lobes are visible as are the cam wheels, belt etc. If this is helpful let me know. It will be Friday eve before I can post.
PostPosted: Fri Jan 18, 2013 2:22 pm
thanks for the picture but it is more about the cam position in the zero position of the engine :)
don, that would be great, currently my intake cam is in the position as shown in the manual but my exhaust is more down, it is around 1/2 teeth but i'll try to know
left or right, currently i'am not sure :)
PostPosted: Fri Jan 18, 2013 2:43 pm
The only way I know to check cam position is with either the notches in the cam (which you don't have) or the timing marks on the pulley with the crank pulley set at TDC. The picture was more to highlight the things you need to look at - cam wheel indexes and the crank timing marker, all of whih should align to their respective markers when it is all correctly timed
I don't think you will be able to look at a photo and judge the correct cam position from that
PostPosted: Sun Jan 20, 2013 12:30 pm
i know but its better then nothing, it would just good to see the cam lobes, some time ago i found a picture where i saw that the intake cam is slighly forwarded
but i'am not able any more to find it.... :(
looks like i have to use my feeling to set it :)
PostPosted: Sun Jan 20, 2013 1:08 pm
Cant you put the standard cam wheels on? set it at TDC then put the new cam gears on? job done?
PostPosted: Sun Jan 20, 2013 2:04 pm
thats a way too, but i don't want to dismount everything any more :lol:
but i could compare both without mounting.....
PostPosted: Sun Jan 20, 2013 8:19 pm
not good, the gen.4 cams also ain't use the notches :(
PostPosted: Tue Jan 22, 2013 8:33 pm
This is just an idea. It needs judgement and care but I think it should work. The only thing is you may need to remove the bolts that hold the can wheels on
Take an OEM can wheel and align it to the notch in the camthatthe woodruf key fits into
Set your adjustable pulley to 0
You should then be able to transfer the timing mark from the OEM pulley to the new one
Since the OEM pulley mark is central to a cam belt tooth it should be reasonsbly safe
PostPosted: Tue Jan 22, 2013 9:26 pm
unfortunetly, my oem cam wheels are at catcams :lol:
but i'am pretty sure that i'am not that wrong, here some pictures
the intake cam looks fine to me as the slot on the end is vertical -> zero position for the dizzy on gen.3 iirc
and the exhaust is slightly advanced, i would guess 1/5 teeth which isn't a problem i think
PostPosted: Sun Jan 27, 2013 12:33 pm
yesterday the work goes on, i built the water lines nearly ready, nearly becouse i have to weld in a bracket to connect both lines so that no motion is possible, unfortunetly i
have to built a two peace bracket connected with a screw so that a later dismounting is possible
