It is currently Sun Oct 05, 2025 11:34 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 22, 23, 24, 25, 26, 27, 28 ... 56  Next
PostPosted: Thu May 19, 2011 8:08 pm
ok was board and some ally sheet left so made this up for the passenger foot well
PostPosted: Thu May 19, 2011 10:07 pm
ooooooh shi8iiney
Looks dead good does that
PostPosted: Thu May 19, 2011 11:10 pm
thanks mate just looking forward to getting it all mapped on tuesday :) having it fully mapped and cams set up :)
PostPosted: Fri May 20, 2011 9:13 am
Is this the first map since the turbo has been clocked?
It would be interesting to see how much power you gain at the same boost from decent pipe routing.
from this Image
to this
PostPosted: Fri May 20, 2011 11:19 am
yes mate it is. And were going to set up the cams this time to.
PostPosted: Fri May 20, 2011 8:22 pm
done a bit more tonight I have made a new and improved rear strut brace
I had some 5mm thick plates made up
but found that the holes were in the wrong place:(
so after a bit or re drilling got the plates to fit :)
got some of the roll cage tube I have and made the brace up
then did a bit of welding
and you end up with this :)
as you can see much thicker and stronger then the stock 1 you can get
just got fill the old holes up and paint it up :)
PostPosted: Mon May 23, 2011 7:56 pm
If you're feeling adventurour, you could triangulate that rear strut brace and take it down to the floor - there's a bolt hole cunningly located there :)
Great work by the way :)
PostPosted: Mon May 23, 2011 7:58 pm
i did think about that but would need to spot on to ge tit all to be in the right place
PostPosted: Wed May 25, 2011 11:47 pm
ok just got back in from having the car mapped and im very happy :)
at the flywheel
at the wheels
PostPosted: Thu May 26, 2011 12:50 am
did you put cams in it?
Good figure for sure :D
PostPosted: Thu May 26, 2011 6:17 am
cams were all read in the car from the first time i built it:) so the extra power is just from good rings and better pipe work, we dident have to do any thing with the cams as thay were all read set to get the max out of them :)
PostPosted: Thu May 26, 2011 9:42 am
Nice numbers m8. Also at 1,4 bar?
ST185 CS #1845
PostPosted: Thu May 26, 2011 10:06 am
no running 1.55-1.6bar
PostPosted: Thu May 26, 2011 2:34 pm
With 370 lb/ft I bet that is a real hoot to drive.
The graphs look like you are still choking at high RPM due to soemthing. Could be the limits of the turbo - close to 400 on a hybrid is pretty darn good going.
PostPosted: Thu May 26, 2011 3:55 pm
yes my mapper said the turbo was dropping off at the hi end. But im happy and for a hybrid thats pritty dam good:)
